Rickey's World :: Discussion Forums :: Discuss and Learn :: Electronics
filter design
priya123
Wed Jun 18 2008, 03:40AM
Registered Member #7113
sir,
Iam very new to the concept of filter designing.I want to design a high pass filter (butterworth) with op-amp .I need a cut-off frequency of .03hz.how should I proceed?
p
sashijoseph
Wed Jun 18 2008, 12:23PM
Registered Member #5870
The simplest configuration for a Butterworth alignment is a Sallen-Key arrangement.Do you want a single pole(6dB/octave) or double pole(12dB/octave) filter?
A double pole SallenKey would look like this :
For a butterworth alignment C1=C2 and R2=2xR1.
The corner frequency is determined by R1 and C1.
For calculating component values first settle on the capacitor value...say 47uF.
Then
R1=0.707/(2*pi*F*C1)
In your case
R1 = 0.707/(2 * 3.14 * 0.03 * 0.000047)
R1=80K
Thus R2=160K
C1=C2=47uF
Let there be music........
This post has been thanked 2 times
 pdi33 , priya123
pdi33
Wed Jun 18 2008, 08:24PM
Registered Member #1329
thanks shashi, very useful info. Hope Priya got the answer :-)
* inspired to develop,developing to inspire *
priya123
Thu Jun 19 2008, 04:11AM
thanx a lot shashi sir,i just want to know if I choose a single pole filterhow will the circuit look like?
sir also provide me the values of capacitors resistors for the respective circuit
[ Edited Thu Jun 19 2008, 04:15AM ]
p
Arun Kumar V
Thu Jun 19 2008, 05:38AM
Registered Member #426
hello priya123,
can we know where you are using this filter- i mean which circuit/application
Arun
sashijoseph
Thu Jun 19 2008, 11:04AM
priya123 wrote ...
A single pole filter will have only a single capacitor-resistor pair. Like this ..
The formula is..
F = 1/(2*pi*R*C)
For F = 0.03Hz and C = 57uF(47uF and 10uF in parallel),R will come to ~93K.
Why have you chosen such a low cutoff? Some medical equipment?
 priya123
priya123
Thu Jun 19 2008, 10:51PM
hello sir,
u are absolutely right ,actually I am trying to design a medical ECG monitoring circuit using instrumentation amplifier ad620a,some filter with a low cut-off,just one more query sir,please tell me how to design a protection/isolation circuit to prevent current leakage.
thanking u.
p
pravin_35
Sun Aug 09 2009, 09:18PM
Registered Member #13089
hi,
for medical application u want to know more abt the signal processing, first wat is the range of frequency you going to monitor.. for u r using protection circuits (isolation)
pravin
