Discussion in "Project Help" started by    isha    Jul 11, 2007.
Wed Jul 11 2007, 01:29 PM
sir, i've a question related to the project named 'Digital Visitor Counter', that ''what type of sensors are used in this project" , complete information about these sensors..... reply me as soon as possible
Thanks
Tags Digital Visitor Countersensors for Visitor counter
Wed Jul 11 2007, 01:46 PM
Thank you for posting it here.. this is going to help others too
so, regarding the sensors, in the project, LDRs are used. LDR = Light Dependent Resistor
There are two LDRs in the circuit, one is on the exit door and on the entrance door.
So when someone crosses the entrance door, it counts the visitor up and when someone crosses the exit door, it decrement the counter.
Timer is setup to refresh the 7-Segment display.
Hope this information is sufficient for the project. If anymore info is needed feel free to ask
 Halley like this.
Sun Dec 21 2008, 11:26 AM
The visitor counter isnt working, some problem in the cde.... the rxd port is not read....
Help!!!
Sun Dec 21 2008, 11:29 AM
I want to shift the inputs to some other port so I can serial port it....
But the circuit code only increments and doesnt decrement....
Sun Dec 21 2008, 11:33 AM
whats the exact problem? are you sure your hardware is ok?
Sun Dec 21 2008, 11:43 AM
i simulated the code on software to make sure its working before i shifted to hardware, and it only increments and doesnt decrement.... sensor circuits work on software... i tried it on hardware and I cant get my sensors to work, but im going to get something of better quality...
the problem seems to be in the rxd port... its not read...
[ Edited Sun Dec 21 2008, 11:54 AM ]
Sun Dec 21 2008, 12:33 PM
how did you make sensor circuit? using switches? which software are u using for simulation? send me hex + ckt if proteus.
Sun Dec 21 2008, 12:59 PM
Your post is not clear.
You're saying it works ok in simulation but not in hardware?
Or it doesn't work in either?
You must remember....for incrementing,the sensor at P3.0 must be obsteucted first and then P3.1
For decrementing,P3.1 must be obstructed first and then P3.0
Fri Jul 17 2009, 01:57 AM
sir in this circuit .how relay will be connected..it is of five pin..but in circuit it is not clear how to connect,..plz help
Sun Jul 19 2009, 06:20 PM
sharik
i saw the circuit and its all clear, your coil is connected with one pin to VCC and other to Q1 transistor.
NO(normally open) is connected to bulb and NC(normally closed) is not connected.
common pin is connected to AC supply.
what is not clear to you, please mention.
One suggestion is to open up a new thread for yourself instead of posting in a thread which is months old
Fri Jul 19 2019, 10:33 AM
charmdatedhd
cooking
Thu Jul 11 2019, 07:55 PM
Thu Jul 11 2019, 07:44 PM
@praveen123. Can you give a link to the project ?
Thu Jul 11 2019, 04:47 PM
ramos
buenos dias alguien podria ayudarme necesito saber como descargar la libreria del l298n para proteus
Thu Jul 11 2019, 11:11 AM
praveen123
anyone can help me
praveen123
i need source code for 8051 -smart trolley rfid
Thu Jul 11 2019, 11:10 AM
praveen123
hii
Thu Jun 27 2019, 09:14 PM
Hi.. good to see you again
۞ TPS ۞
Thu Jun 27 2019, 07:31 AM
Hello
AdiGhazi
Tue Jun 18 2019, 11:21 AM
Hlo Dear , I've to program AT89C51AC3 RT-LUM using flip but I'm getting time out error for RS232. Will you please suggest me which programmer will be supportable to program this Chip.
rpels7707
Fri Jul 19 2019, 11:31 AM
ameya123
Fri Jul 19 2019, 07:36 AM
anhsieuno
Thu Jul 18 2019, 11:39 AM
zxcvbnm1234
Sat Jul 13 2019, 07:09 AM
surajghayal
Wed Jul 10 2019, 01:17 PM
figureyang
Fri Jul 05 2019, 04:25 AM
mousompal
Sat Jun 29 2019, 05:02 PM
AdiGhazi
Tue Jun 18 2019, 11:15 AM
Guests: 43, Members: 0 ...
Members: 38080
Newest member: rpels7707
Forum Activity
ameya123 Avatar
Posted By ameya123
Fri Jul 19 2019, 07:42 AM
Hello,Please share 8051 Assembly language code for...
figureyang Avatar
Posted By figureyang
Fri Jul 05 2019, 04:37 AM
here is the source code prepared for you download ...
figureyang Avatar
Fri Jul 05 2019, 04:30 AM
Cheap_Flash_FS(Normal Version)--Embedded FAT16/32 ...
wimac Avatar
Posted By wimac
Sat Jun 22 2019, 01:26 PM
I’ve use the AT89C51ED2 which has a similar progra...
ExperimenterUK Avatar
Posted By ExperimenterUK
Thu Jun 20 2019, 10:08 PM
baud rate is 9600 at stop bits of 2. AdiGhaziThe u...
AdiGhazi Avatar
Posted By AdiGhazi
Thu Jun 20 2019, 05:24 AM
Dear,I'm using RS232 serial port cable to use flip...
Tue Jun 18 2019, 10:19 PM
Okay.. I have never programmed the AT89C51AC3 or ...
AdiGhazi Avatar
Posted By AdiGhazi
Tue Jun 18 2019, 11:20 AM
Hlo Dear ,I've to program AT89C51AC3 RT-LUM using ...
Thu May 30 2019, 08:32 PM
It occurs to me that although the P89LPC921 and P8...
Wed May 29 2019, 09:05 PM
I would suggest a fresh approach.The Keil compile...
