Discussion in "Project Help" started by    prashants    Aug 4, 2007.
Sat Aug 04 2007, 02:45 PM
hi ,
i want to interface SD card to ATmega 16/128 ,so i want help for how to interface the card & how i write the data to it , any file system is required for that card.
Sat Aug 04 2007, 03:17 PM
you can use the AVRlib it got APIs to write and read in SD/MMC also IDE. you can download AVRlib from here...
AVRlib 2007-03-31
Documentation can be found here.. : Documentation
[ Edited Sat Aug 04 2007, 03:21 PM ]
Tags AVRlibC-Language Function Library for Atmel AVR ProcessoAVR Library
Thu Nov 01 2007, 04:02 AM
Hi, do you have similar files but instead for the 8051?
Thu Nov 01 2007, 07:26 AM
no.. because only the recent S series of 8051 family (AT89S8252, AT89S8253) by atmel has SPI interface otherwise it was very rare in 8051 to find SPI on chip. So maybe in future someone will make it..
Here is a sample code for AVR actually.. but i will give a little info on how can u change it to 8051
 * MMC Init function
 * - flushes card receive buffer
 * - selects card
 * - sends the reset command
 * - sends the initialization command, waits for card ready
int MMCInit(void)
unsigned int i;
unsigned char Byte;
SPIDDR = SCLK + MOSI + CS + MMCPOWER;
SPIPORT = 0x00;
Delay_1ms(500);
SPIPORT |= MMCPOWER;
SPIPORT |= CS;
SPCR = (1<<SPE) | (1<<MSTR) | (1<<SPR1) | (1<<SPR0);    /* enable SPI as master, set clk divider */
Delay_1ms(250);
/* start off with 80 bits of high data with card deselected */
for(i=0;i<10;i++)
SpiByte(0xff);
SPIPORT &= ~CS;        /* select card */
/* now send CMD0 - go to idle state */
MMCCommand(0,0,0);
if (MMCGet() != 1)
   SPIPORT |= CS;
   return -1;  // MMC Not detected
/* send CMD1 until we get a 0 back, indicating card is done initializing */
i = 0xffff;
while ((SpiByte(0xff) != 0) && (--i))
     MMCCommand(1,0,0);
     WDR();
if (i == 0)
   SPIPORT |= CS;
   return -2;  // Init Fail
SPIPORT |= CS;
return 0;
 * void MMCInfo(void)
 * - gets and prints formatted CID and CSD info from card
void MMCInfo(void)
int i;
MMCCommand(10,0,0);
if (MMCDataToken() != 0xfe) TxString("MMC: error during CID read\n\r\0");
else TxString("MMC: CID read\n\r\0");
// Skip 3 byte Manufacturer ID
SpiByte(0xff);
SpiByte(0xff);
SpiByte(0xff);
TxString("MMC: Product Name : ");
for (i=0;i<7;i++) TxChar(SpiByte(0xff));
TxString("\n\r\0");
for (i=0;i<9;i++) SpiByte(0xff); // Read 9 left byte
SPIPORT |= CS;
 * int MMCReadSector(unsigned long lba, unsigned char * s)
 * - reads a sector from the card (512 bytes)
 * - takes sector # as param
int MMCReadSector(unsigned long lba, char *s)
unsigned int i;
MMCCommand(17,(lba>
7) & 0xffff, (lba<<9) & 0xffff);
   SEI();
   return -1;
for (i=0;i<512;i++)     /* read the sector */
    *s++ = SpiByte(0xff);
SpiByte(0xff);          /* checksum ->
 don't care about it for now */
SPIPORT |= CS;
return 0;
 * int MMCWriteSector(unsigned long lba, unsigned char * s)
int MMCWriteSector(unsigned long lba, char *s)
unsigned int i;
MMCCommand(24, (lba>
7)& 0xffff, (lba<<9)& 0xffff);
if (MMCGet() == 0xff) return -1;
SpiByte(0xfe);  // Send Start Byte
    SpiByte(*s++);
SpiByte(0xff);       /* Read "data response byte"                 */
i = 0xffff;
while ((SpiByte(0xff) == 0x00) && (--i)); /* wait for write finish */
if (i == 0) return -1; // Error
SPIPORT |= CS;
return 0;
 * unsigned char MMCGet(void)
 * - pings the card until it gets a non-0xff value
 * - returns one byte of read info
unsigned int i = 0xffff;
unsigned char Byte = 0xff;
while((Byte == 0xff) && (--i)) Byte = SpiByte(0xff);
return Byte;
 * int MMCDataToken(void)
 * - pings the card until it gets data token
 * - returns one byte of read info (data token)
unsigned char MMCDataToken(void)
while((Byte != 0xfe) && (--i)) Byte = SpiByte(0xff);
return Byte;
 * void MMCCommand(unsigned char command, unsigned int px, unsigned int py)
 * - send one byte of 0xff, then issue command + params + (fake) crc
 * - eat up the one command of nothing after the CRC
SPIPORT &= ~CS;
SpiByte(0xff);
SpiByte(command | 0x40);
SpiByte((unsigned char)((px >
 8)&0x0ff)); /* high byte of param y */
SpiByte((unsigned char)(px & 0x00ff));     /* low byte of param y */
SpiByte((unsigned char)((py >
 8)&0x0ff)); /* high byte of param x */
SpiByte((unsigned char)(py & 0x00ff));     /* low byte of param x */
SpiByte(0x95);            /* correct CRC for first command in SPI          */
                          /* after that CRC is ignored, so no problem with */
                          /* always sending 0x95                           */
SpiByte(0xff);
 * Main SPI routine
 *  - transmits a byte and receives a byte simultaneously
 *  - received byte is returned
 *  - if you only want to read a byte, put a dummy
 *    (say 0xff) in the transmit slot
unsigned char SpiByte(unsigned char byte)
WDR();
SPDR = byte;               /* put byte to send in SPDR, which initiates xmit  */
while(!(SPSR & (1<<SPIF)));/* wait for completion */
return SPDR;               /* return with byte shifted in from slave */
If you can write the SpiByte routine for 8051 then you can use the above code to read and write to MMC. further there might be many more changes needed.. that you need to find out.
For more reference take a look at these documents
SD Memory Card Physical Layer Specification, version 1.01 (pdf)
SanDisk SD Card Product Manual v1.9 (pdf)
SanDisk SD Card Product Manual v2.2 (pdf)
Simplified SDIO Card Specification, version 1 (pdf)
also...
How programm SD Card :
http://hdf.ncsa.uiuc.edu/training/HDFtraining/tutorial/sd/sds.html
Link about socket to SD Card :
http://www.sparkfun.com/shop/index.php?shop=1&itemid=330
Project soft and schematic of connecting PIC to SD Card.
http://www.captain.at/electronics/pic-mmc/
MSP430 interfacing to SD card doc from Ti :
http://focus.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=slaa281&fileType=pdf
Fri Aug 01 2008, 07:33 AM
what does MMCCommand(1,0,0) mean?? :blush
Fri Aug 01 2008, 03:07 PM
i will upload Hitachi specifications for MMC and SD soon in download section. Do check it back soon. you will come to know everything.
Sat Aug 09 2008, 06:28 PM
thanks sir
Sat Aug 09 2008, 06:45 PM
i have just checked the download section. May i know in which section you upload the file? Thanks
Mon Aug 11 2008, 06:10 AM
please check the download section
Mon Aug 11 2008, 08:19 AM
oh yea, i want to ask. Is MMC same to SD??
Wed Sep 18 2019, 08:48 PM
Caryn Kover
Thank you for your time,
Mon Aug 05 2019, 07:09 PM
Mon Aug 05 2019, 04:33 PM
Ismail balghmi
Wed Jul 24 2019, 12:47 AM
@BUSTER123 Please post in the forum
Tue Jul 23 2019, 06:13 PM
BUSTER123
hello! newbie here. i am kind of a guy who hates using ready - made existing libraries, so this helped a lot as i was trying to control and write to a character lcd display. however, i can't figure out how to set the cursor position. for example, i want to set it to the 5th column in the first row, so position 5. so according to the table, i am sending 10000101 on the 8 data lines of the lcd (register select pulled low). the cursor does not move there however. and i cant move the cursor left or right too. is it something wrong that i am doing? thank you.
Thu Jul 11 2019, 07:55 PM
Thu Jul 11 2019, 07:44 PM
@praveen123. Can you give a link to the project ?
Thu Jul 11 2019, 04:47 PM
ramos
buenos dias alguien podria ayudarme necesito saber como descargar la libreria del l298n para proteus
Thu Jul 11 2019, 11:11 AM
praveen123
anyone can help me
praveen123
i need source code for 8051 -smart trolley rfid
ramon_vsc
Fri Sep 20 2019, 04:53 PM
youssoufba
Thu Sep 19 2019, 11:57 AM
Taiphan000
Tue Sep 17 2019, 04:21 AM
mawantha
Fri Sep 13 2019, 10:42 AM
jonelily954
Mon Sep 02 2019, 12:34 PM
electrobyte
Sat Aug 31 2019, 03:24 AM
Moutonajj
Sun Aug 25 2019, 09:30 PM
jualanled
Sat Aug 17 2019, 03:41 AM
Guests: 38, Members: 0 ...
Members: 38092
Newest member: ramon_vsc
Forum Activity
nick@IT Avatar
Posted By [email protected]
Wed Aug 07 2019, 10:38 AM
I am trying to execute USSD codes through my GSM m...
ExperimenterUK Avatar
Posted By ExperimenterUK
Sun Jul 28 2019, 08:55 PM
An LM339 may not be fast enough for reliable SPI ...
sakibnaz Avatar
Posted By sakibnaz
Sun Jul 28 2019, 06:40 AM
Hi All.I need to connect my MCU with an external S...
Wed Jul 24 2019, 10:42 PM
Your unit is communicating, so I assume the GPS si...
Wed Jul 24 2019, 10:32 PM
Have you read this ?http://www.8051projects.net/wi...
manu8193 Avatar
Posted By manu8193
Wed Jul 24 2019, 04:57 AM
any one tell me the explaination and 'c' code for ...
3AAPC Avatar
Posted By 3AAPC
Sun Jul 21 2019, 12:51 AM
3AAPC Avatar
Posted By 3AAPC
Sun Jul 21 2019, 12:47 AM
With the GPS antenna in the outdoors, I use the ub...
ameya123 Avatar
Posted By ameya123
Fri Jul 19 2019, 07:42 AM
Hello,Please share 8051 Assembly language code for...
figureyang Avatar
Posted By figureyang
Fri Jul 05 2019, 04:37 AM
here is the source code prepared for you download ...
