Help to debug error in my code
kvbhat123
Sat Mar 07 2009, 06:58PM
Registered Member #16211
I along with our group members made a code for home automation .It was working with few warnings but now suddenly the warnings have increased without any modification of code.I am attaching all header along with main.c pls help me to debug this....
If possible guide me to bring down the warnings
waiting for your reply Ajay sir
code.rar
DavesGarage
Sat Mar 07 2009, 08:05PM
Registered Member #14254
kvbhat,
I downloaded your files and compiled them with Keil C51. I included the default startup.a51 file, and have NO errors or warnings when I compile your MAIN.C file.
Since you did not include the source modules for the other files, I cannot build the entire thing.
Can you please show the warnings you are getting?
Thanks,
-Dave
-Dave
kvbhat123
Sun Mar 08 2009, 12:26AM
what exactly do we need sir apart from those give here(files)
waiting for your reply!!
DavesGarage
Sun Mar 08 2009, 10:20AM
From your question, I assume this isn't your software, but something you borrowed from someone else. Is this the case? If not, I apologize, but the question seems odd. If you could screen print your screen after you get the warnings, you could attach the picture to this forum so I could better understand what problems you are having. This would be very helpful in fully understanding your problem.
To answer your question, your RAR file included these files:
Obviously, I don't need to see the included library files from Keil, because I assume they are correct.
In case you don't know what I am talking about, that would be anything having to do with the functions listed in stdio.h and 89c51.h - These header files are for a library that comes with Keil and a register definition file, that also comes with Keil, repectively.
However, you have header files called delay.h, lcd4,h, adc.h, serial.h, fbus.h, and keymatrix.h. These must have source modules that have source code for the function prototypes in the headers.
In order to compile the entire project, I would need these modules.
I hope this helps you,
-Dave
[ Edited Sun Mar 08 2009, 10:23AM ]
-Dave
 kvbhat123
Sun Mar 08 2009, 12:56PM
Rickey's World Admin
can you provide what errors you are getting?
www.rickeyworld.info
Obey forum rules!
Respect others!
 kvbhat123
kvbhat123
Mon Mar 09 2009, 07:12PM
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
SYMBOL: _DELAYI
MODULE: Main.obj (MAIN)
ADDRESS: 1FF6H
this and many more similar to this are the warnings.
You are right sir i havent done the entire code myself ,took help of my friends and some of them are currently out of town..
Even if the warning persist and i burn the code in microcontroller will the code work??
Thnx for the reply
DavesGarage
Mon Mar 09 2009, 11:59PM
No, it will not work without resolving the warnings. These warnings indicate that there are external functions that the linker cannot find. The one you specifically show here is the Delay function. No doubt, it is in one of the missing modules I was referring to.
You must include these modules in your project, and then compile and link them together for this software to work...
Sorry,
Dave
-Dave
 kvbhat123
kvbhat123
Tue Mar 10 2009, 02:03AM
Thank you very much for the help.
I got the source code from my friend and works without any warning..
again thank you very much for ur help and support....:-|:-|
 rdvarma
rdvarma
Thu Apr 02 2009, 05:01AM
Registered Member #17187
hey dude, i saw ur problem of programming microcontroller......even i have same problem....can u please give me source codes for header files that u have posted on forums??
thanx mann
