8051 flash programmer and debugger
8051dev_89
Thu May 21 2009, 08:58PM
Registered Member #18698
Hi Everyone,
I have newly joined to this forum. I have just started working on 8051 and made a generic 8051 dev board using AT89C51, but iam facing the following problems.
1. How to flash program my application as i donot have a programmer.
2. I want to do target debugging.
Could somebody suggest how to go ahead.
Thanks in advance,
Regards,
8051dev_89
RUSHI D.
Thu May 21 2009, 09:05PM
Registered Member #5507
pls c 'Help regarding Programmer' thread on d home page
Regards
Rushi D. :-)
8051dev_89
Thu May 21 2009, 09:13PM
Thanks for the reply.
I want to do target debugging how to proceed with that.
Thanks again,
Regards,
8051dev_89
8051dev_89
Thu May 21 2009, 09:32PM
I have actually got stuck up because of this for the past 15days. So, some suggestion is highly appreciated.
Thanks and Regards,
8051dev_89
RUSHI D.
Fri May 22 2009, 12:38AM
wat exactly do u mean by target debugging,,?
i'll suggest u to make urself a programmer n den burn ur code n test it..
ve u gone through d thread i'hd mention..?
all d best..!
Regards
Rushi D. :-)
8051dev_89
Fri May 22 2009, 01:11AM
yeah i have taken a philips micro and able to flash program it and test it. But what iam trying to say is if i flash the entire code iam unable to find the problems in the code. so i want to flash the program on the target with all the required hardware connected (ex: LCD connected or I2C device connected) and then run the code in the target in single step mode(on PC), able to put a breakpoint, watch the memory in the PC. In short i want to emulate the micro ( i hope we get some monitor program for this??).
Please let me know if iam not clear in explaining the problem.
waiting for your reply
Thanks and Regards,
8051dev_89
RUSHI D.
Fri May 22 2009, 04:01AM
k..got it..
but i don know any such facility available with normal 8051..
there is one controller 4m analog devices called ADuC841(8051 core)..it comes along with a software called "aspire" where u can emulate ur code..
but d whole ADuc841 kit is a costly affair...
so i'll sugest u,if u've any doubts wid d code,discuss it here n den burn d code into ur controller..
dis is d best soln,i guess..!
Regards
Rushi D. :-)
8051dev_89
Fri May 22 2009, 04:13AM
ok. then i will start writing the code but i am not sure how much time it is going to take and whether i will be able to add all the features required for emulating, may be i can find something is already available in the internet.
let me know your comments
Regards,
8051dev_89
RUSHI D.
Fri May 22 2009, 09:48AM
just do wat i said..
test ur code in ur compiler itself n den download it into ur controller,it will work surely..
or we'll make it work..
all d very best..
Regards
Rushi D. :-)
