Need help for making "Rolling display using Matrix LEDs"
rushi53
Mon Jun 01 2009, 11:31PM
Registered Member #18965
Hi I am want to make a Rolling message display for which I want to use Matrix LED display.
can someone help me for this.
MATHIVANAN
Tue Jun 02 2009, 12:18AM
Registered Member #2569
Left to Right:
Initially just Display the (Starting) One Letter in Left side. Give the delay for 50ms and Display the first letter to next position from right to left,Second Letter in the first position. Give the delay for 50ms. Again do the same procedure continuously in the Loop.
I respect others the same way i expect from others.
rushi53
Tue Jun 02 2009, 01:17AM
Hey MATHIVANAN, thanks for the quick reply, I appreciate your comments.
But problem is that I am not using the readymade matrix display, instead I want to design a PCB where I will solder normal 5mm LEDs.
Reason behind this is that the readymade Matrix display are small in size and I want to design a size of approximately 10cm by 15cm so that it is visible from a long distance.
For this I need a circuit design from basic. I would appreciate if you provide me a circuit diagram or some help regarding circuit diagram
Tue Jun 02 2009, 06:38AM
Rickey's World Admin
build something.. will tell you if its right or wrong.. and how to modify it. or just google.. you will get many circuits.
www.rickeyworld.info
Obey forum rules!
Respect others!
MATHIVANAN
Wed Jun 03 2009, 06:48AM
I think this is the circuit what you want.
led-dot-matrix-display.pdf
 rushi53
rushi53
Wed Jun 03 2009, 10:36PM
Hey MATHIVANAN, thanks for the circuit diagram,
Now I can start working on this...
THANKS a TON !!!
Thu Jun 04 2009, 02:11PM
Registered Member #9602
rushi53 wrote ...
It is one way, but may not be the best way for you.
It may be better to consider other methods before committing yourself.
You want a 10cm by 15cm display. Have you decided how many leds you will have up and across ?
[ Edited Thu Jun 04 2009, 02:13PM ]
rushi53
Thu Jun 04 2009, 09:12PM
ExperimenterUK wrote ...
Hi ExperimenterUK,
I want to use a matrix of 7 by 5 LEDs
I mean 7 rows and 5 columns
Like shown below:
o o o o o
o o o o o
o o o o o
o o o o o
o o o o o
o o o o o
o o o o o
Thu Jun 04 2009, 11:31PM
OK.. 5* 7 will be for 1 digit/character,
how may digits/characters wide do you want the display to be ?.
