IC chip for 8051 C8051f226DK
jason1987
Wed Jun 03 2009, 11:00PM
Registered Member #19032
anyone can help mi with tis IC chip.. i was ask to write a program using silicon software anyone know abt tis software? and i giving a variable resister to let the LED dimmer.. and using ADC n PWM to generate it.. isit possible? and hw to write the program out? i hv totally no idea about tis.. kinda email mi at jason1987@hotmail.com. thank or post here
c8051f2xx-dk.pdf
aaaa
Fri Jun 05 2009, 12:39AM
Rickey's World Admin
Jason, go through the datasheet,
start with reading ADC value, display it somewhere like on serial terminal, once you are done with ADC, go for PWM. Generate PWM signal with using onchip PWM generator, then combine both.
To understand how PWM makes LED dim, visit PWM tutorial in tutorial section:
http://www.8051projects.net/microcontroller-tutorials/
Finish the first two parts then i will tell you how you can combine.
We do not give code but we do give guidance
www.rickeyworld.info
Obey forum rules!
Respect others!
Obey forum rules!
Respect others!
