Serial port reading
P Thirumeni
Tue Jun 16 2009, 11:52PM
Registered Member #15992
Hi all
I have a programme which gives HEX codes through serial port to switch relays, i want to copy this codes (HEX) coming out from serial port to PORT1 of the 8051.
Can anyone help me with the code.
nalthirumeni@yahoo.com
PT
Thu Jun 18 2009, 02:59AM
Rickey's World Admin
post the program you have written for switching relays..
www.rickeyworld.info
Obey forum rules!
Respect others!
P Thirumeni
Thu Jun 18 2009, 04:08AM
Dear Sir
Thanks for your help.
I am attaching the folder containing the exe file.
Please d.click on Relayplayer icon
Ignore the registration and press OK
1. Press stop button
2. Press play button
3.Music come from speaker
4.Also sequentially ASCII/HEX codes comes from serial port (you can use HDD serial port monitor or other to see)
5.For example IF 01 relay to be switched on the 01 HEX codes comes out
all 8 relay means 255 diferent combination from 1 to 8 relay we get diff. codes
I want this hex codes to be copied to PORT1 /2 of 8051
I tried MOV P1,#H28 and other such codes not working.
I request the admin to delete the file after seeing.
Pl. help.
Thanks
PT
P Thirumeni
Thu Jun 18 2009, 04:16AM
Hi
Here is the attachment
(file removed as requested) ExperimenterUK
[ Edited Thu Jun 18 2009, 11:27AM ]
P Thirumeni
Thu Jun 18 2009, 04:25AM
Sir pl. not you have to add Demo file from Data1 folder ....
then press stop and press play
PT
P Thirumeni
Sir pl. note you have to add Demo file from Data1 folder ....
PT
P Thirumeni
Thu Jun 18 2009, 09:31PM
Thanks Experimenter and Admin.
Hoping for a reply.
Thanks
PT
Mon Jun 22 2009, 02:16PM
i think you are writing instruction in wrong way..
try
CODE:
MOV P1,#28H
;if you are storing in some location say 30H then move to port like this
MOV P1, 30H
;if you using an equ for a location say Store equ 30H then
MOV P1, Store
do tell me how you're storing the value. what does this program do :-s its so confusing..
Obey forum rules!
Respect others!
P Thirumeni
Mon Jun 22 2009, 09:27PM
Hi
First thank you sir
I will try the code and give the feedback.
Thanks
P Thirumeni
rearthur2003
Tue Jun 23 2009, 06:24AM
Registered Member #10733
can you be more specific for assistance
