Hello to all, I am beginner, i am using AT89c51 MCU. I was program the following program. Checked all the connection which i was found in the same forum (www.8051projects.net/forum-t10422.html), but LED did not blink. Program was compile with no error in SIDE51 sotware(demo) also used as making HEX file. Plz help me
check the code i dont know of the software you are using but from the code i can say you have not define the port as output or input and try to specsify which bit to blink P1 is for the whole of port1
Thanks, Now it is working.But second problem is happened , I am using universal adoptor(1.5V, 3V, 4.5V, 6V, 7.5, 9V) for power supply.When i switch on the power supply, LED does not blink(LED in continusely on). When i three four times on off on off the switch LED start blinking. This happen always in same pattern. I am using Cap.10 uf 50V instead of Cap. 10 uf 25v.Where is the problem i cannot found.
hi, is it compulsary to make CHIP SELECT CS (BAR) = 1 aftr WRITE wr(bar ) and READ rd(bar) hv been changed to trigger conversion and to read data respectively ??
