Can anyone help me select a microcontroller which has two serial ports. I prefer if the controller is compatible with ATMEL 89S51 or its other models so that the code can be the same. I want to code it in Assembly language.
I want to use one serial port with RS-232 and the other one with RS-485.
Thank you ExperimenterUK, I have read a little bit whats on that page.
I have two questions
Will i need a separate program burner for this IC Will the same code for 8051 work with this (I know that IC name does contain 8051 but i want to be sure) Photoshop Tutorials
download its datasheet, and see programming information. Most probably, its gonna be ISP programmable i.e. no special programmer needed. www.rickeyworld.info If you feel satisfied with the user's forum reply please click on the thank button.
Shyam is talking about software UART tutorial avaiable in the tutorials section of this website. He was suggesting that i try implementing a serial port via software
I still dont have any leads in the two serial port ATMEL microcontroller .. just keep on looking. Photoshop Tutorials
