help mi
jason1987
Mon Jun 29 2009, 07:57PM
Registered Member #19032
what does the following code do?
CODE:
#include<c8051f200.h> //
//definitions
sbit LED = P2^4;
void adc_init(); //to initialize adc
void port_init(); //to initialize the ports
unsigned int index=0, total_period= (unsigned int) 255*256, on_time=0;
port_init();
adc_init();
   // disable watchdog timer
   WDTCN = 0xde;
   WDTCN = 0xad;
        ADBUSY = 0x01;                          //starts the adc conversion
        while(ADCINT);                            //polling for ADCINT which tells us the end of conversion
        ADCINT = 0x00;
        on_time = ((unsigned int)ADC0H)*256;
        for ( index = 0 ; index < total_period ; index++)
            if (on_time--)
                LED = 0x01; //switching on the LED
            else
                LED = 0x00; //switching off the LED
void adc_init ()
    AMX0SL = 0x3f;                         // enable AMUX & configure for p3.7 as i/p pin
    ADC0CF = 0x60;                         // set conversion clk at one sys clk and PGA at gain =1
    ADC0CN = 0xC0;                         // ADC is enabled and ADBUSY=0 (changed here)
    REF0CN = 0x03;                         // VDD is selected as Vref. Here are you using VDD for variable resistor also?
void port_init()
    P3MODE = 0X7F;                   // Except the P3.7 pin all are configured as digital I/O
[ Edited Fri Jul 03 2009, 04:54AM ]
aaaa
tcs89
Tue Jun 30 2009, 02:18AM
Registered Member #19683
help help
Fri Jul 03 2009, 05:02AM
Rickey's World Admin
looks like its a PWM code.
you have on time defined by ADC and off time is total_period - ontime
www.rickeyworld.info
Obey forum rules!
Respect others!
