8051 microcontroller and 4 7segment display....pls help
Go to page       >>
dgkadesewa
Thu Jul 02 2009, 03:56AM
Registered Member #19400
hey every1....i'm programming a STK microcontroller which is an 8051 microcontroller in c language. the program makes the 7segmant count down from 9999 to 0 on a 4 7segment display. i want the 4 7segment to start blinking when it gets to 50 and blink till it gets to 0 i.e blink every second..and oh i forgot to add the delay is for 1 second.
i'v programmed the microcontroller and it counts down without a problem...bt d problem comes in the blinking part....d blinking is nt in uniform n i think its cos each digit is controlled separately at a different time....its blinkin could synchronize for 20secs and then go out of phase for d next 10 secs , go back in phase for d nxt 5 secs n ends out of phase......nxt time, it alternates i.e go out of phase for the 20 secs...go back in phase n d rest....sorrry i cnt give ma code now..bt i promise to do so..soon....
i desperately need an ansa..its drivin me nuts...PLSSSSS HELP....and oh!...am using d keil uvision compiler and proteus 7 professional simulator.....tnx in advance
in Christ and with Christ for ever...
dgkadesewa
Thu Jul 02 2009, 08:51AM
c'mon guysss....i tot we had geniuses on dis forum...quit viewin n nt repling...instead, view n reply.........plsss
Thu Jul 02 2009, 10:28AM
Registered Member #9602
If you could post your project.. code and proteus simulation it would help.
ali.mir10v
Thu Jul 02 2009, 09:01PM
Registered Member #13351
Decrement the value of unit place and also decrment a counter whihch will test for a count upto 950 as follows ( four user define counter cnt1 = ff, cnt2 = ff, cnt3 = ff ,cnt4 = 87h). As 950 occurs set a user define bit which will say the controller that already 950 count are completed now start dec with blinking
And you can now do the blinking with decrementing the unit place digit , setting all 7 segment OFF calling delay and setting all four 7 segment as per order,
Hai na simple...Reply me if this work or not.Plz PM me.
no zodiac sign but believe in the hardwork:-)
dgkadesewa
Fri Jul 03 2009, 06:57AM
ok.. dis is my source code..it counts down from 999 to 0 and starts blinking when it gets to 995...
CODE:
#include<reg51.h> //
void delay(){
int b;
for(b=0;b<23;b++){
TMOD=0x01;
TH0=0x00;
TL0=0x00;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay2(){
TMOD=0x01;
TH0=0xF7;
TL0=0xF0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay21(){
TMOD=0x01;
TH0=0xF8;
TL0=0x00;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay22(){
TMOD=0x01;
TH0=0xF8;
TL0=0xF0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay23(){
TMOD=0x01;
TH0=0xF9;
TL0=0xF0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay4(){
TMOD=0x01;
TH0=0xF9;
TL0=0xF0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay5(){
TMOD=0x01;
TH0=0xFA;
TL0=0xF0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay6(){
TMOD=0x01;
TH0=0xFF;
TL0=0xF0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
void delay3(){
TMOD=0x01;
TH0=0xF7;
TL0=0xC0;
TR0=1;
while(TF0==0);
TR0=0;
TF0=0;
int decode (int digit)
        int acode;
        switch(digit)
                case 0: acode = 0x40; break;
                case 1: acode = 0x79; break;
                case 2: acode = 0x24; break;
                case 3: acode = 0x30; break;
                case 4: acode = 0x19; break;
                case 5: acode = 0x12; break;
                case 6: acode = 0x02; break;
                case 7: acode = 0x78; break;
                case 8: acode = 0x00; break;
                case 9: acode = 0x10; break;
                case 24:acode = 0xff; break;
        return acode;
int thousands, hundreds, tens, units;
int  thingy(int count)
        if(count<1000 && count>99){
        thousands = 24;
        hundreds = count%1000/100;
        tens = count%1000%100/10 ;
        units = count%1000%100%10;}
        else if(count<100 && count>9)
        thousands=24;
        hundreds=24;
        else if(count<10)
        thousands=24;
        hundreds=24;
        tens=24;
        else{
        thousands = count/1000;
        return thousands,hundreds,tens,units;
        int countnum,time;
while(1){
                for (countnum=999; countnum >= 0; countnum-- )
                                if(countnum<=995)
                                                thingy(countnum);
                                                P2=1;
                                                P3=decode(thousands);
                                                delay3();
                                                P3 = 0xff;
                                                delay2();
                                                P2=2;
                                            P3=decode(hundreds);
                                                delay4();
                                                P3 = 0xff;
                                                delay21();
                                                P2=4;
                                                P3=decode(tens);
                                                delay5();
                                                P3 = 0xff;
                                                delay22();
                                                P2=8;
                                                P3=decode(units);
                                                delay5();
                                                P3 = 0xff;
                                                delay();
                                        else{
                        thingy(countnum);
                                for(time=0;time<82;time++)
                        P2 = 0x01;
                        P3 = decode(thousands);
                        delay2()        ;
                        P3 = 0xff;
                        delay2();
                        P2 = 0x02;
                        P3 = decode(hundreds);
                        delay2();
                        P3 = 0xff;
                        delay2();
                        P2 = 0x04;
                        P3 = decode(tens);
                        delay2();
                        P3 = 0xff;
                        delay2();
                        P2 = 0x08;
                        P3 = decode(units);
                        delay2();
                        P3 = 0xff;
                        delay2();
pls help....
am having troubles uploadin d simulation..bt will do dat as soon as i can......1 more fin how can i attach a file in dis forum..
[ Edited Sat Jul 18 2009, 08:58AM ]
tweety bird
Fri Jul 03 2009, 11:08AM
Registered Member #7329
u gotta be kiddin me... :mad
such a big code for such a small problem...!!
follow ari.mir10v suggestions..
n try make da code small.. !!! u using so many delay routines, just use 1 ...
dgkadesewa
Sat Jul 04 2009, 03:30AM
au wld i do dat?.....n i strted out wiv one delay bt i still had d same problems so i decided to av varyind routines and all...bt all i nid right now is the way forwad...help..
au wld i get to ari.mir10v suggestions....gogled it n didnt find anyfing.....
Mon Jul 06 2009, 02:28AM
Rickey's World Admin
to attach a file, zip the file and use the "POST REPLY" button on the top right or bottom right corner of forum.
or use the preview buttom of quick reply form.
www.rickeyworld.info
Obey forum rules!
Respect others!
dgkadesewa
Mon Jul 06 2009, 04:11AM
uhm..ajay..au abt an answer to my question concerning the 4 7segment display...thank you..
afilash
Fri Jul 17 2009, 02:58PM
Registered Member #20315
adesewa,
here is the pseudo code, if you haven't got the answer yet :-)
// this will blink the display 10 times if count is less than 50
initialize_timerx for say 50ms
let var_b = 9999
let var_a = 20
blink = 0
here:
go to sleep -- idle mode
is var_b == 0( put blink as 0 ; var_b as 9999)
loop here
timerx_interrupt:
is var_b < 50 ?( compliment blink)
is blink == 0( display var_b else switch off display )
dec var_a
is var_a == 0? ( dec var_b and put var_a = 20 again )
[ Edited Fri Jul 17 2009, 03:00PM ]
Go to page       >>
