AT89C5131 project = How to change LENGTH OF REPORT Value (greater than 32 bytes)
Aniolek
Thu Jul 02 2009, 08:00AM
Registered Member #19894
Hello,
I'm working on the c5131_usb_generic file. I'm sending datas from my USB device to my PC.
The LENGHT OF REPORT is define as 0x20, I'd like to send 128 bytes, but when I change the value of the LENGHT OF REPORT to 0x80, the device isn't recognised by the PC! I can change the value only if it is lower than 0x20.
Does someone has managed to make a change of the LENGHT OF REPORT value to send mores than 32 bytes?
Maybe it's impossible to do this with this microcontroller.
Thanks :bye
Isabel
[ Edited Fri Jul 03 2009, 02:34AM ]
Fri Jul 03 2009, 06:30AM
Rickey's World Admin
can you post the link to file or code?
www.rickeyworld.info
Obey forum rules!
Respect others!
Aniolek
Mon Jul 06 2009, 02:50AM
Of course, I've taken the code on atmel website :
http://www.atmel.com/dyn/resources/prod_documents/c5131-usb-generic-1_2_0.zip
I've modified the file user_application.c like this, more accurately:
CODE:
void user_application_task (void)
  int var = 0;
  int i,j=0;
  unsigned char* chaine;
  chaine = (char*) calloc (256,sizeof(unsigned char));
  chaine = "000110101101010010101010101011001101010101010101010
101010100101010101010101010101010101010101010101010101010101
010101010101010101010101010101010101010101010101010101010101
010101010101101010010101011001010101100101101010101010100101
011010010110101010010101011001101001011010101010101010101010
101010010101100101100101101001101010010110101010010101010101
010101010110011001100101100110011001011000110101101010010101
010101011001101010101010101010101010100101010101010101010101
010101010101010101010101010101010101010101101010010101011001
010101100101101010101010100101010101010101010101010101010101
010101010101010101010101010101011010010110101010010101011001
101001011010101010101010101010101010010101100101100101101001
101010010110101010010101010101010101010110011001100101100110
0110010110111"
  if(Is_new_data_read())
       usb_read_continuous(data_received);
           if((data_received[0]=='1')&&(data_received[1]=='1'))
           j=0;
                                                 for(i=0;i<29;i++)
                                  data_to_send[i] = chaine[j];
                                  j++;
                                data_to_send[i] = '\0';
                                usb_write_continuous(data_to_send,30);
           if((data_received[0]=='1')&&(data_received[1]=='2'))
           j=29;
                                                 for(i=0;i<29;i++)
                                  j++;
    if (INT0_button != last_INT0_button_state)   // INT0 button pressed
       if (Is_write_data_ready())
          data_to_send[0] = !INT0_button;
          last_INT0_button_state = INT0_button;
    if (reset_to_bootloader == TRUE)
       Usb_detach();
       Led_all_off();
       Enable_ale();
       Configure_led(0,STANDARD_PORT);
       Configure_led(1,STANDARD_PORT);
       Configure_led(2,STANDARD_PORT);
       Configure_led(3,STANDARD_PORT);
       for (data_received[0]=0; data_received[0]<250; data_received[0]++);
       Usb_disable();
       Pll_stop();
       EA = 0;
       MAP_BOOT;
       __API_JMP_BOOTLOADER();
[ Edited Mon Jul 06 2009, 02:57AM ]
