Rickey's World :: Discussion Forums :: Discuss and Learn :: General help Guidance and Discussion
Which value of inductor should use ?
Baban
Fri Jul 03 2009, 04:04AM
Registered Member #19086
Hi all,
I am driving 10 relays of 5v operated, with the microcontroller,and uC also operates o the 5V spply . So single 5V supply is to be used for both. Now say all 10 relays will drive simoultaneously then current spike will generate and it may appear on the microcontroller syppy too. So to protect uC i am planning to use and inductor in series in between them . So that spike will not appear at the controller input pin . So please suggest that which value of inductor should be used in this case?
Baban
Remainder
Fri Jul 03 2009, 06:11AM
Rickey's World Admin
Check the attached pdf file for inductor calculation.
also make sure you have diodes across the relay coil.
inductor_cap_esd_design_in_switch_regulator.pdf
www.rickeyworld.info
Obey forum rules!
Respect others!
 Baban
