problem with eeprom write.. plz help..... :(
Go to page       >>
tweety bird
Mon Jul 06 2009, 11:24AM
Registered Member #7329
i have been working on eeprom interfacing since last few days...
i successfully ran my project on proteus.... the eeprom read n write works fine....
but when i burnt my at89s52, the program didnt run on it as thought of... the eeprom write encounters some problems i dont know wat, but on reading back eeprom i get only garbage characters on lcd screen...
the problem seems to come after write data byte to eeprom, i dont seem to get ack from eeprom...
void mem_write(unsigned char value)
char j;
bitchar=value;
for(j=0;j<8;j++)
scl=0; // to clock in data
sda=msbc;
scl=1;
bitchar=bitchar<<1;
scl=0; // to receive ack from eeprom
scl=1;
scl=0;
delay(3);
the above code works fine in proteus but not in real project... i use pagewrite to write to eeprom.... plz help
DavesGarage
Mon Jul 06 2009, 08:51PM
Registered Member #14254
What part are you trying to write to? What is the part number - a link to the data sheet would also be helpful.
-Dave
tweety bird
Tue Jul 07 2009, 12:52AM
oops.. i have been trying to write to 24c16 atmel eeprom....
first i send dev adress = 0xA0, them mmry word address = 0x00 ... then 16byte page write seq ...
start
devadd(0xa0)
memadd(0x00)
for(i=0;i<16;i++)mem_write(arr[i]);
stop
tweety bird
Tue Jul 07 2009, 10:46AM
DavesGarage
Tue Jul 07 2009, 11:16AM
Is this your memory device?
http://atmel.com/dyn/products/product_card.asp?part_id=3513
-Dave
DavesGarage
Tue Jul 07 2009, 11:22AM
Also, is this how you have it connected?
Remember, for someone to help, they must first understand what you are doing. Without a part description, and a schematic, it is very difficult to write software...
Please try and be specific when asking for help...
-Dave
tweety bird
Tue Jul 07 2009, 11:33AM
ya dat is the eeprom .. n dat is how i have connected it ..
tweety bird
Tue Jul 07 2009, 11:38AM
void mem_datawr() // starts the sequence of writing data to eeprom
char i;
rstart();
mem_write(dev_addw); // load dev_add into eeprom
mem_write(mem_addw);
for(i=0;i<16;i++,mem_addw++)
{mem_write(arr[arr_count++]); // writes contents of arr[16] to eeprom using pagewrite
if(sda!=0){led=0; delay(20); led=1; delay(20); }
stop();
delay(3);
above function is used to write data to eeprom .. in proteus simulator , it works perfectly... but not in my real project .. dont know y...
in my real prog, led keeps on blinkin indicating of not receiving proper ack... ((
DavesGarage
Tue Jul 07 2009, 11:47AM
Next, how fast are you talking to the device? Have you measured your data stream with an o-scope?
The part has a maximum frequency of 400kHz...
Are you within this boundary?
-Dave
Wed Jul 08 2009, 05:35AM
Rickey's World Admin
just make sure your memory is not busy in writing data to EEPROM.
give sufficient delay after writing, normally 5ms or more. try 1 byte at a time to test.
www.rickeyworld.info
Obey forum rules!
Respect others!
Go to page       >>
