TITLE: Reliable Vehicle Control System
eleceng123
Sat Jul 11 2009, 04:00PM
Registered Member #16089
HELLO GUYS, JUST NEED HELP IN MY PROJECT.
AM STILL MAKING RESEARCH AND ANALYSING MATERIALS AND HOW TO DO IT THO ITS DUE IN TWO MONTHS OR SO, GUYS ALL I NEED IS ANALYSIS AND HW U THINK I CAN DO THIS IN A SHORTER PERIOD AND IT WOULD BE A GOOD PROJECT
This project is to design and construct an in-building positioning system based on wireless or other principles that will enable a mobile unit to determine its position as it navigates rooms, corridors and so forth. If possible the system should be cheap and accurate to within a couple of metres.
If time permits the system should be integrated into a "moving map" that is present on the mobile device to assist in the navigation process or to locate specific objects
MY CURRENT DECISION NOW IS TO USE
1. 2 STEPPER MOTORS FOR REAR WHEEL
2. A UNIDIRECTIONAL WHEL IN FRONT OF THE VEHICLE
3. CONNECTIONS THRU PARALLEL PORT
PLS I NEED YOUR HELP
elec elec 1
shyam
Sat Jul 11 2009, 09:25PM
Registered Member #2984
hi eleceng123,
Nice idea. Have you decided any further ?
We would certainly help if required.
all the best.
lProgress is not made by early risers or hard workers, but by LAZY people, trying to find easier ways to do the same........
Mon Jul 13 2009, 11:47AM
Rickey's World Admin
 User Online
well.. i would suggest you to make something like what GPS do..
create your own satellite, or say local satellites, they are nothing but small short range transmitters and will transmit ID of the place after every second or shorter interval decided by you.. I am not sure this method may void your idea of having a cost effective system. but it can be a reliable system.
www.rickeyworld.info
Obey forum rules!
Respect others!
