Rickey's World :: Discussion Forums :: Discuss and Learn :: E-books and Tutorials :: PIC
PIC nid extent port!
jovenlim89
Wed Sep 02 2009, 07:23PM
Registered Member #21860
HI.. I m using PIC16F877A..
But I nid more port for my project..I was suggest that using shift register and latch..But I dunno how to do it? Can any1 send me the circuit pls...:-|
Hope u all can help me~Thx..
Chiru
Wed Sep 02 2009, 08:55PM
Registered Member #6023
One way of extending port is by using the 82C55. Download datasheet for detailed information, keep in mind the speed limit. Ofcourse you need to write a code for the interface.:bye
jovenlim89
Wed Sep 02 2009, 09:06PM
Thx so much... The code that I need to write is at PIC or the chip u mention js now? Hope can get more tips from u..
Thu Sep 03 2009, 09:04AM
Registered Member #9602
Given the cost of chips these days I would consider adding another PIC as a slave.
Use a high speed serial link to read and update the ports on the slave PIC.
How many more ports do you need ?
jovenlim89
Sat Sep 05 2009, 02:40AM
lolx..Thanks...I m oso thinking of it... I need about 39 port for my project..Do you think adding another PIC is the best way? And what do u mean by use a high speed serial link?
Sat Sep 05 2009, 04:10AM
Rickey's World Admin
Registered Member #1
high speed serial link means, serial communication over higher speed/data rate. you ca use either uart on higher baud or SPI at higher data rate.
using extra controller is good, but you should also make sure it matches your project requirement. the shift register latch (CD4094) is commonly used for port expanding coz it need only 3 pins to make an 8 bit port. and no extra pins needed if you want to go further expansion of ports.
www.rickeyworld.info
Obey forum rules!
Respect others!
jovenlim89
Sat Sep 05 2009, 06:58AM
Thanks Ajay...If shift register latch just can expand 8 port by usinf 3 port, that mean that my PIC16F877A have 33port and use 3 for shift register latch.After expand, I will get 38 right? But if get 38 port, I still lack of 1 slot... Haha! Anyway..Thank you so much.. If you all got anymore way,please suggest here...Thanks~
Sat Sep 05 2009, 11:31AM
By port do you mean 1 pin or 8 pins ?
What do you need the extra pins/ports for ?.
jovenlim89
Sat Sep 05 2009, 08:47PM
Omg...I am so sorry...I have wrong typing.. It should be pin...To get extra pin, I should have extra port right? I am planing to use the extra pin to make my lcd display..And also my matrix keypad... Anyhow, thank you so much! I am still new, I will make mistake frequenly.So sorry ExperimenterUK..
Sun Sep 06 2009, 02:21PM
jovenlim89 wrote ...
No problem
A port usually has 8 pins, so an extra port will give an extra 8 pins.
A simple shift register is probably be the best option, unless a slave PIC
would be useful to handle other functions of the project.
[ Edited Sun Sep 06 2009, 02:28PM ]
