any help me!
vanbayhoang
Sat Oct 31 2009, 06:25PM
Registered Member #23375
Here is sechematic, please any one provide me asembly code for communicate with 8255 using 89c51!
thanks!
sorry!, My english is not good!
[ Edited Sat Oct 31 2009, 08:18PM ]
Sun Nov 01 2009, 05:56AM
Rickey's World Admin
Registered Member #1
First of all, please try not to create multiple threads.
Now, 8255 has got 4 registers, which can be selected with combination of A0 and A1 address pins of 8255.
00 = PortA
01 = PortB
10 = PortC
11 = Control register.
you need to configure control register to control the IO ports.
From the circuit diagram you posted address will be like this
E000 = PortA
E001 = PortB
E002 = PortC
E003 = Control Register
do access these registers you can use MOVX instruction. user DPTR to point to this address.
www.rickeyworld.info
Obey forum rules!
Respect others!
vanbayhoang
Sun Nov 01 2009, 06:21AM
thanks! you have code asembly beforehand ( you writed), send your code to me.
Sun Nov 01 2009, 10:22AM
well i do not have the code with me. but its simple.
CODE:
mov DPTR, #0E000H
mov a,#54H ;data to move
movx DPTR,a ;send data to register 0E000
the above code is just example of how to move data to 8255 register. so configure 8255 in IO mode and then use it as normal IO port.
if you are new to 8255 then check this page
http://www.thesatya.com/8255.html
also see datasheet for more info.
Obey forum rules!
Respect others!
DavesGarage
Sun Nov 01 2009, 09:30PM
Registered Member #14254
You better check that address again, Dude... I see 0x1XXX for the address base.
In other words 0x1000, 0x1010, 0x1020...0x1FF0 all will address Port A
and 0x1001, 0x1011, 0x1021...0x1FF1 all will address Port B
and so on...
Those inverters make this so...
-Dave
Mon Nov 02 2009, 10:50PM
oops!
my mistake.. address will be as given by dave
Obey forum rules!
Respect others!
