HELP on using LDR and ADC0804 in 8051 Assembly
mark_627
Mon Nov 02 2009, 07:59AM
Registered Member #23415
Hi everyone.
I need help on how to use LDR and ADC0804 in 8051 microcontroller.
So far I have this in my project but I want to replace the switch with LDR(dark activated).
What happens here (attached file) is that I use the switch to decrement/increment the number of cars and when it reaches zero (meaning no available space) the LCD will prompt that it is full.
What I want is using a sensor (ldr) and a laser light so that when a car passes (the light will be broken) the ldr will send a signal and decrement the number of spaces and vice versa ( i'll be using two ldr one for exit the other for entrance).
attached is my design. Im using Isis Proteus 7.4 and the code below
CODE:
DB0 EQU P1.0
DB1 EQU P1.1
DB2 EQU P1.2
DB3 EQU P1.3
DB4 EQU P1.4
DB5 EQU P1.5
DB6 EQU P1.6
DB7 EQU P1.7
EN EQU P3.7
RS EQU P3.6
RW EQU P3.5
DATA EQU P1
;7-Segment Display
enableDIGIT3 EQU P3.2
enableDIGIT4 EQU P3.3
ZERO   EQU   10001000b
ONE     EQU   10111110b
TWO     EQU   11000100b
THREE   EQU   10010100b
FOUR   EQU   10110010b
FIVE   EQU   10010001b
SIX     EQU   10000001b
SEVEN   EQU   10111100b
EIGHT   EQU   10000000b
NINE   EQU   10010000b
DOT     EQU   01111111b
MOV 20h,#ZERO
MOV 21h,#ONE
MOV 22h,#TWO
MOV 23h,#THREE
MOV 24h,#FOUR
MOV 25h,#FIVE
MOV 26h,#SIX
MOV 27h,#SEVEN
MOV 28h,#EIGHT
MOV 29h,#NINE
MOV R0, #20h
MOV R1, #22h
PDATA EQU P2 ; Connect 8 pins here
CLR 51h
LCALL LCD_WELCOME
Start:
        JB P3.1, check1
                SETB 50h
        check1:
        JB P3.0, check2
                SETB 52h
        check2:
                JNB P3.1, cont1
                        JNB 50h, cont1
                                CLR 50h
                                LCALL INC_7SEGMENT
        cont1:
                JNB P3.0, cont2
                        JNB 52h, cont2
                                CLR 52h
                                LCALL DEC_7SEGMENT
        cont2:
                LCALL SHOW_7SEGMENT
                LCALL SHOW_LCD
SJMP Start
SHOW_LCD:
        CJNE @R0, #ZERO, welcome
        CJNE @R1, #ZERO, welcome
                JB 51h, done_showlcd
                LCALL LCD_FULL
        sjmp done_showlcd
        welcome:
                JNB 51h, done_showlcd
                LCALL LCD_WELCOME
        done_showlcd:
RET
LCD_FULL:
        LCALL CLEAR_LCD
        LCALL INIT_LCD
        CLR RS
        MOV DATA,#086H
        SETB EN
        CLR EN
        LCALL WAIT_LCD
        MOV A,#'F'
        LCALL WRITE_TEXT
        MOV A,#'U'
        LCALL WRITE_TEXT
        MOV A,#'L'
        LCALL WRITE_TEXT
        MOV A,#'L'
        LCALL WRITE_TEXT
        MOV A,#'!'
        LCALL WRITE_TEXT
        MOV A,#'!'
        LCALL WRITE_TEXT
        SETB 51h
RET
LCD_WELCOME:
        LCALL CLEAR_LCD
        LCALL INIT_LCD
        CLR RS
        MOV DATA,#081h
        SETB EN
        CLR EN
        LCALL WAIT_LCD
        MOV A,#'P'
        LCALL WRITE_TEXT
        MOV A,#'A'
        LCALL WRITE_TEXT
        MOV A,#'R'
        LCALL WRITE_TEXT
        MOV A,#'K'
        LCALL WRITE_TEXT
        MOV A,#'I'
        LCALL WRITE_TEXT
        MOV A,#'N'
        LCALL WRITE_TEXT
        MOV A,#'G'
        LCALL WRITE_TEXT
        MOV A,#' '
        LCALL WRITE_TEXT
        MOV A,#'S'
        LCALL WRITE_TEXT
        MOV A,#'P'
        LCALL WRITE_TEXT
        MOV A,#'A'
        LCALL WRITE_TEXT
        MOV A,#'C'
        LCALL WRITE_TEXT
        MOV A,#'E'
        LCALL WRITE_TEXT
        CLR RS
        MOV DATA,#0C3h
        SETB EN
        CLR EN
        LCALL WAIT_LCD
        MOV A,#'A'
        LCALL WRITE_TEXT
        MOV A,#'V'
        LCALL WRITE_TEXT
        MOV A,#'A'
        LCALL WRITE_TEXT
        MOV A,#'I'
        LCALL WRITE_TEXT
        MOV A,#'L'
        LCALL WRITE_TEXT
        MOV A,#'A'
        LCALL WRITE_TEXT
        MOV A,#'B'
        LCALL WRITE_TEXT
        MOV A,#'L'
        LCALL WRITE_TEXT
        MOV A,#'E'
        LCALL WRITE_TEXT
        CLR 51h
RET
INC_7SEGMENT:
        CJNE @R1, #TWO, increment
        sjmp doneinc
        increment:
                CJNE @R0, #NINE, incr0
                MOV R0, #20h
                INC R1
                SJMP doneinc
                incr0:
                        INC R0
        doneinc:
RET
DEC_7SEGMENT:
        CJNE @R0, #ZERO, dec0
        CJNE @R1, #ZERO, dec1
        sjmp donedec
        dec1:
                MOV R0, #29h
                DEC R1
                SJMP donedec
        dec0:
                DEC R0
        donedec:
RET
SHOW_7SEGMENT:
        MOV PDATA,#00h
        setb enableDIGIT3
        MOV     A,@R1
        MOV PDATA,A
        LCALL smallDelay
        clr enableDIGIT3
        setb enableDIGIT4
        MOV     A,@R0
        MOV PDATA,A
        LCALL smallDelay
        clr enableDIGIT4
RET
INIT_LCD:
        CLR RS
        MOV DATA,#38h
        SETB EN
        CLR EN
        LCALL WAIT_LCD
        CLR RS
        MOV DATA,#0Ch
        SETB EN
        CLR EN
        LCALL WAIT_LCD
RET
CLEAR_LCD:
        CLR RS
        MOV DATA,#01h
        SETB EN
        CLR EN
        LCALL WAIT_LCD
RET
WRITE_TEXT:
        SETB RS
        MOV DATA,A
        SETB EN
        CLR EN
        LCALL WAIT_LCD
RET
WAIT_LCD:
        CLR EN ;Start LCD command
        CLR RS ;It's a command
        SETB RW ;It's a read command
        MOV DATA,#0FFh ;Set all pins to FF initially
        SETB EN ;Clock out command to LCD
        LCALL smallDelay
        MOV A,DATA ;Read the return value
        JB ACC.7,WAIT_LCD ;If bit 7 high, LCD still busy
        CLR EN ;Finish the command
        CLR RW ;Turn off RW for future commands
RET
smallDelay:
                CLR TF1
                CLR TR1
                MOV TH1,#76
                MOV TL1,#01
                MOV TMOD,#01
                SETB TR1
                JNB TF1,$
RET
[ Edited Mon Nov 02 2009, 08:10AM ]
Embedded Systems present themselves as a challenge.
mark_627
Mon Nov 02 2009, 08:19AM
Im sorry about the photo.when i resized it to fit the screen in the attachment the connections of the wires got blurry you cant even see them but they are there.. :|
Arun Kumar V
Mon Nov 02 2009, 05:01PM
Registered Member #426
you don't have to use an ADC or LDR, you can use a photo transistor or photodiode and connect to port pin via a transistor. its better to use modulated IR bcoz it provides immunity to day light.
Arun
mark_627
Tue Nov 03 2009, 08:03AM
@Arun:
Sir, thanks for the reply.:)
Can you provide me a circuit diagram on using the photodiode and transistor to the port pin? I would very much appreciate it.
THANKS a million.
I will gladly wait for your response.
Wed Nov 04 2009, 04:21AM
Rickey's World Admin
Registered Member #1
small search on google is always helpful
you can also try it
www.rickeyworld.info
Obey forum rules!
Respect others!
