Discussion in "Electronics" started by    ۞ TPS ۞    Nov 3, 2007.
Sat Nov 03 2007, 03:41 PM
[S-Video]
Pin Name Description
1 GND Ground (Y)
2 GND Ground (C)
3 Y Intensity (Luminance)
4 C Color (Chrominance)
[SCART]
13 R GND RGB Red Ground
15 R RGB Red In / Chrominance
17 VGND Composite Video Ground
20 VIN Composite Video In / Luminance
Pin 1 on the S-Video connector -> Pin 17 on the SCART connector.
Pin 2 on the S-Video connector -> Pin 13 on the SCART connector.
Pin 3 on the S-Video connector -> Pin 20 on the SCART connector.
Pin 4 on the S-Video connector -> Pin 15 on the SCART connector.
Sat Nov 03 2007, 04:23 PM
can you put diagrams or some images? what is s-video and scart? :-s
Sun Nov 04 2007, 12:07 AM
s-video is Short for Super-Video, a technology for transmitting video signals over a cable by dividing the video information into two separate signals: one for color (chrominance), and the other for brightness (luminance). When sent to a television, this produces sharper images than composite video , where the video information is transmitted as a single signal over one wire. This is because televisions are designed to display separate Luminance (Y) and Chrominance (C) signals. (The terms Y/C video and S-Video are the same.)
Computer monitors, on the other hand, are designed for RGB signals. Most digital video devices, such as digital cameras and game machines, produce video in RGB format. The images look best, therefore, when output on a computer monitor. When output on a television, however, they look better in S-Video format than in composite format.
To use S-Video, the device sending the signals must support S-Video output and the device receiving the signals must have an S-Video input jack. Then you need a special S-Video cable to connect the two devices.
now most vcd/dvd players have s-video pin
 ajay_bhargav like this.
Tags s-videos-video connections
Sun Nov 04 2007, 12:12 AM
A SCART connector is a physical and electrical interconnection between two pieces of audio-visual equipment, such as a television set and a video cassette recorder (VCR). Each devicehas a female 21-pin connector interface. A cable with a male plug at each end is used to connect the devices. (The 21st pin is actually not a pin but a ground shield contact.) Stereo audio, composite video, and control signals are provided in both directions. RGB video signals are input only. The interface is an industry standard originated by the French company, Peritel. Today, most new television sets and VCRs in the European market and other countries that use the PAL video standard come equipped with a SCART connector. SCART stands for Syndicat francais des Constructeurs d'Appareils Radio et Television. The connector is also known as a Euro-connector.
[ Edited Sun Nov 04 2007, 12:13 AM ]
Tags scartscart connectionsscart pin description
Sun Oct 13 2019, 02:02 AM
Aline Hutchinson
Hey there,
Sat Oct 12 2019, 10:23 PM
Sat Oct 12 2019, 10:18 AM
Bhadra Sajikumar
Mon Sep 23 2019, 07:37 AM
Nathaniel
Wed Sep 18 2019, 08:48 PM
Caryn Kover
Thank you for your time,
Mon Aug 05 2019, 07:09 PM
Mon Aug 05 2019, 04:33 PM
Ismail balghmi
Wed Jul 24 2019, 12:47 AM
@BUSTER123 Please post in the forum
Tue Jul 23 2019, 06:13 PM
BUSTER123
hello! newbie here. i am kind of a guy who hates using ready - made existing libraries, so this helped a lot as i was trying to control and write to a character lcd display. however, i can't figure out how to set the cursor position. for example, i want to set it to the 5th column in the first row, so position 5. so according to the table, i am sending 10000101 on the 8 data lines of the lcd (register select pulled low). the cursor does not move there however. and i cant move the cursor left or right too. is it something wrong that i am doing? thank you.
Thu Jul 11 2019, 07:55 PM
ilylily07
Tue Oct 15 2019, 04:32 PM
hientran123
Tue Oct 15 2019, 02:27 AM
Sat Oct 05 2019, 02:38 PM
zexalo
Thu Oct 03 2019, 09:53 AM
thanhle12345
Thu Oct 03 2019, 07:37 AM
ramon_vsc
Fri Sep 20 2019, 04:53 PM
youssoufba
Thu Sep 19 2019, 11:57 AM
Taiphan000
Tue Sep 17 2019, 04:21 AM
Guests: 41, Members: 0 ...
Members: 38097
Newest member: ilylily07
Forum Activity
s_dinesh40@yahoo.com Avatar
Posted By [email protected]
Sun Oct 20 2019, 03:09 PM
Sun Oct 20 2019, 03:02 PM
sir, when i on display ,sometime 3rd display is no...
Sun Oct 20 2019, 02:53 PM
ExperimenterUK Avatar
Posted By ExperimenterUK
Sun Oct 20 2019, 12:21 AM
Your code seems okay on my simulationTry my code o...
Sat Oct 19 2019, 07:13 PM
please find video attachment. 3rd & 4th displa...
Sat Oct 19 2019, 07:05 PM
sir, 3rd and 4th dot matrix display flickering, ...
Fri Oct 18 2019, 09:18 PM
Hopefully you understand some of the program.Which...
Thu Oct 17 2019, 09:38 PM
Thu Oct 17 2019, 08:35 PM
Do you understand how this code works?If so, addin...
