Discussion in "Project Help" started by    dez    Jan 7, 2008.
Mon Jan 07 2008, 07:32 AM
Hello,
I have to finish and make a report about the project below in a week.
My problem is: I dont have hardware part now and i m wondering how to simulate my assembly program in any sofware. I m used to simuate in Proteus Isis. But i dont know how to build the circuit with RS232 in ISIS.
Can anybody help me?
Thanks in advance!
an Assembly Language Program to control a DC Motor interfaced to a PC through the parallel port. The project contains the following modules:
1. Motor Driving Module (Output Module):
· The motor will rotate clockwise if f (forward) key is pressed and will rotate anticlockwise if r (reverse) key is pressed.
· The speed of the motor will be changed by introducing different PWM signals with changing duty cycles.
2. Speed Display Module (Output Module):
· The speed of rotating motor will be indicated by displaying a single digit 7-segment display. There will be speeds from 0 to 9. The speed which is displayed on the 7-segment display will also be displayed on the monitor with its direction (clockwise or anticlockwise).
· The positive speeds will be shown as they are (from 0 to 8) and the negative speeds will be displayed in two’s complement form.
3. Up and Down Push Buttons (Input Module):
· The speed of the motor will be controlled by the two external push buttons (Up and Down) connected to the PC through the parallel port. The speed will be incremented or decremented one by one by pushing to Up or Down buttons respectively.
Mon Jan 07 2008, 09:55 AM
u can use virtual terminal in instruments section or COMPIM (in devices) to simulate serial port.
Mon Jan 07 2008, 09:59 AM
Yeah I know this. Thanks.
But i couldnt do it properly. Can you give me a link? or maybe a tutorial working properly.
I m not sure with my problem. It may be because of ports :S
[ Edited Mon Jan 07 2008, 10:00 AM ]
Mon Jan 07 2008, 10:09 AM
i dont have any tutorial or link :-| . but if u tell what problem you are facing :-| we can solve it :-)
Mon Jan 07 2008, 10:46 AM
If it is possible, can you make a little circuit working properly, that includes rs232 is connected to 1 led and i can test it by using "out #,data" command.
You may send to my emai: [email protected] or upload anywhere and everybody can see it in the future.
Mon Jan 07 2008, 01:09 PM
There is no need of using COMPIM. Just make circuit on proteus.. with DC motor connected.. and make use of virtual terminal provided in the proteus.
For driving a DC motor.. you need a H-Bridge circuit commonly available as L293D IC. But simulation of this IC is not available so make use of transistor based H-bridge.. you can take a look at the sample circuit from the DC Motor tutorial.. BJT based H-Bridge demo is given...
Just make the simulation circuit... and it will work perfectly. if you feel any problem i am here..
Mon Jan 07 2008, 01:40 PM
and tell me if u want to simulate L293D :-) i have its simulation model
Mon Jan 07 2008, 01:58 PM
wow... mail me..
Mon Jan 07 2008, 02:36 PM
try if it works in this way
L293D Spice model
HIDDEN - LOGIN AND REPLY TO REVEAL
[ Edited Mon Jan 07 2008, 03:51 PM ]
Tags L293D proteusspice model L293d ProteusL293D simulation model proteus
Mon Jan 07 2008, 02:51 PM
I want to put it in the download section.. so asking you if its working or not..
can you give me a screenshot of it? i am not on my PC hence no softwares..
Sat Jul 20 2019, 05:38 AM
charmdatexvo
cooking
Thu Jul 11 2019, 07:55 PM
Thu Jul 11 2019, 07:44 PM
@praveen123. Can you give a link to the project ?
Thu Jul 11 2019, 04:47 PM
ramos
buenos dias alguien podria ayudarme necesito saber como descargar la libreria del l298n para proteus
Thu Jul 11 2019, 11:11 AM
praveen123
anyone can help me
praveen123
i need source code for 8051 -smart trolley rfid
Thu Jul 11 2019, 11:10 AM
praveen123
hii
Thu Jun 27 2019, 09:14 PM
Hi.. good to see you again
۞ TPS ۞
Thu Jun 27 2019, 07:31 AM
Hello
AdiGhazi
Tue Jun 18 2019, 11:21 AM
Hlo Dear , I've to program AT89C51AC3 RT-LUM using flip but I'm getting time out error for RS232. Will you please suggest me which programmer will be supportable to program this Chip.
rpels7707
Fri Jul 19 2019, 11:31 AM
ameya123
Fri Jul 19 2019, 07:36 AM
anhsieuno
Thu Jul 18 2019, 11:39 AM
zxcvbnm1234
Sat Jul 13 2019, 07:09 AM
surajghayal
Wed Jul 10 2019, 01:17 PM
figureyang
Fri Jul 05 2019, 04:25 AM
mousompal
Sat Jun 29 2019, 05:02 PM
AdiGhazi
Tue Jun 18 2019, 11:15 AM
Guests: 62, Members: 0 ...
Members: 38080
Newest member: rpels7707
Forum Activity
ameya123 Avatar
Posted By ameya123
Fri Jul 19 2019, 07:42 AM
Hello,Please share 8051 Assembly language code for...
figureyang Avatar
Posted By figureyang
Fri Jul 05 2019, 04:37 AM
here is the source code prepared for you download ...
figureyang Avatar
Fri Jul 05 2019, 04:30 AM
Cheap_Flash_FS(Normal Version)--Embedded FAT16/32 ...
wimac Avatar
Posted By wimac
Sat Jun 22 2019, 01:26 PM
I’ve use the AT89C51ED2 which has a similar progra...
ExperimenterUK Avatar
Posted By ExperimenterUK
Thu Jun 20 2019, 10:08 PM
baud rate is 9600 at stop bits of 2. AdiGhaziThe u...
AdiGhazi Avatar
Posted By AdiGhazi
Thu Jun 20 2019, 05:24 AM
Dear,I'm using RS232 serial port cable to use flip...
Tue Jun 18 2019, 10:19 PM
Okay.. I have never programmed the AT89C51AC3 or ...
AdiGhazi Avatar
Posted By AdiGhazi
Tue Jun 18 2019, 11:20 AM
Hlo Dear ,I've to program AT89C51AC3 RT-LUM using ...
Thu May 30 2019, 08:32 PM
It occurs to me that although the P89LPC921 and P8...
Wed May 29 2019, 09:05 PM
I would suggest a fresh approach.The Keil compile...
