Discussion in "Project Addition or Changes" started by    Shehwar    Aug 19, 2011.
Fri Aug 19 2011, 09:51 am
hi guys
i already made the propeller display using 89c51.
i must say that this project is really amazing!!!
Now i need to modify the program for 3 different modes.
1. Analog clock display
2. Digital clock display
3. Message mode display.
i want to do it in real time. And i need help with the code.
Please help me with the code and circuit diagram for it. I am currently working on the code and will post it here shortly. But i also need help with modifications in the circuits so as to
1. Change the modes
2. Set the time in both analog and digital
3. To enter a message using an interface.
i really want to make this happen guys so please help me out.
and please please reply with any suggestions , links or codes that may help.
Fri Aug 19 2011, 08:31 pm
@ Shehwar
make a separate code for each mode and then test it
when test is ok for each mode after that u can make a final code
that will combine the 3 modes in this way coding and debugging will be easy for u
Sun Aug 21 2011, 12:55 pm
trickry part is to make the clock hands on runtime... digital clock however is simpler... you can try making it first
Sun Aug 21 2011, 09:14 pm
Ajay has a point.
Making a digital clock is relatively easy, making an analogue clock would be a challenge
even for an experienced programmer.
[ Edited Sun Aug 21 2011, 09:16 pm ]
Sun Aug 21 2011, 10:00 pm
my problem is not in making but in changing the program as you understand... I have the propeller display project ready with my name displaying on it i just need the editing part in program so as to create a clock.
I will use one of the ports to set the time.
Sun Aug 21 2011, 11:03 pm
Shehwar
By "making" I meant programming.
To get the analogue effect of moving hands you need to light certain LEDs
as the display rotates...sounds complicated.
Mon Aug 22 2011, 07:31 am
yes hence i am trying for the digital first.
I have a code for it but it is for a pic.
Do you know what modifications must i do in order to make it for 89c51 ?
Mon Aug 22 2011, 08:32 pm
well the only difference here is that you will have display test to be generated on runtime rather than stored on a specific location. so instead of reading from 600H location (current code is written to read string from this location) read from ram where you clock time is present.
i suggest use DS1307 RTC so you can have real time clock whenever you power on your display. read from RTC, store in ram after converting to ascii.... figure out what need to change i gave you lot of hints and ideas hope to see some progress now good luck..
Tue Aug 23 2011, 03:58 am
ajay bro i have another suggestion
instead of going through the trouble of using 2 pcbs, 3 relimate connectors...
can we use 1 single pcb for the entire circuit ?
If so can we use the dotted pcb to make it happen ?
and as far as the 3mode part is concerned, i have some info on the code for a pic and i have no clue as to what that is.
FYI this was my 1st microcontroller based project .
So can you help me with the changes in code ?
Tue Aug 23 2011, 09:43 pm
Shehwar
i really have no idea what you're talkin about i mean in what context.. you can build as you want.. just make sure you dont modify the circuit
Shehwar
First is always important in life... First project means you will learn a lot.. and by the way.. i think i helped a lot with hints in my last post. You better understand the original codes, get comfortable with assembly coding then start with project. here on this website you will always find people ready to help.. but you cant expect anyone to give you ready codes.
StephenHauct
Sat Apr 27 2024, 09:38 am
Adamsaf
Sat Apr 27 2024, 07:12 am
