Discussion in "Project Addition or Changes" started by    Shehwar    Aug 19, 2011.
Tue Sep 27 2011, 11:04 pm
#31
yes i compiled it with keil.
Did you take a look at the pic propeller clock ?
If you have the time please do so.i wanna make this work.
Wed Sep 28 2011, 11:22 am
#32
@ Shehwar
i think it not directly compiler in keil some syntax error after that it compile in keil
Wed Sep 28 2011, 03:18 pm
#33
yes the 1st line needs to be commented i.e. Include reg51
Wed Sep 28 2011, 05:18 pm
#34
@ Shehwar
burn with this hex file and check is any change
Wed Sep 28 2011, 10:31 pm
#35
which hex file
Thu Sep 29 2011, 12:34 am
#36
@ Shehwar
i am trying to attach 2 times
but in previous post due to server problem not attached
still i am not able to attach
give me ur mail id i sent there when problem solve also upload here
Fri Sep 30 2011, 05:26 pm
#37
i tried but no effect
what must i do ?
Does anyone know where i can buy this project ?
Fri Sep 30 2011, 10:22 pm
#38
@ Shehwar
i don't know from where u can buy it
probably crystal is not working or any thing else
now in a whole assembly can't say surely what is wrong
now start testing one thing at a time so by step by step u come to know which is wrong
suppose first verify controller is working or not
make a led blinking program and burn into controller and see is it running
after that it will clear that controller part is ok then come to MOC part and see it is it working
Sun Oct 02 2011, 05:47 pm
#39
you can write a small program to test MOC part if its working during rotation. LIT up an LED when it passes once and turn it off when it passes again. this will atleast ensure MOC is working. coz i feel controller is not able to judge speed of rotating assembly.
Sat Oct 08 2011, 02:05 pm
#40
can i use the multipattern led program given on this forum ?
Also for that project what is the circuit assembly ?
HenryLaf
Mon Apr 22 2024, 03:50 pm
bleradrar
Mon Apr 22 2024, 06:38 am
ppu-pro_ka
Sun Apr 21 2024, 07:39 pm
Infewow
Sun Apr 21 2024, 06:30 pm
