Discussion in "Project Addition or Changes" started by    adambose1990    Oct 11, 2011.
Tue Oct 11 2011, 05:32 pm
Hi guys, here is a simple project I have done in 89s52 IC of 8051 series. Making a Digital Clock.
Components required:
1 microcontroller 89C52(89S52 will also do)
2 ceramic capacitors-22pF
1 switch(button for reset purpose)
1 electrolytic capacitor-10uF,25V
1 crystal oscillator-11.0592MHz
16x2 LCD display
1 resistor-10k
Software you will need:
The programming of the microcontroller is done using keil compiler. Port 2 is output port, This LCD is in 8bit mode.
Details of LCD you can have here.
http://www.mikroe.com/eng/chapters/view/17/chapter-4-examples/
Circuit Diagram:
The detail explanation of the code is done below:
//main.c
#include <REG51.H>
#include "lcd.h"
void ms_delay(int time)
	unsigned int i,j;
	for(i=0;i<time; i++)
		for(j=0;j<=1275;j++);
void main(void)
   	int hr=00,min=00,sec=00,flag=0;
	LCD_init();
   	LCD_putnum(hr,2);		   //|HH:MM:SS 	AM
   	LCD_sendstring(":");
	LCD_putnum(min,2);
	LCD_putnum(sec,2);
	LCD_sendstring("  AM");
	for (sec=0;sec<60;sec++)
		LCD_gotoxy(6,0);
		LCD_putnum(sec,2);
		ms_delay(142);
		if (sec==59)
			min=min+1;
			if(min==60)
		  		if(hr==11&&sec==59)
					hr=0;
					min=0;
					sec=-1;
					flag=~flag;
					LCD_gotoxy(0,0);
					LCD_putnum(hr,2);
					LCD_gotoxy(3,0);
					LCD_putnum(min,2);
					LCD_gotoxy(10,0);
					if (flag==0)
						LCD_sendstring("AM");
					else
						LCD_sendstring("PM");
		  		else
					hr=hr+1;
					min=0;
					LCD_gotoxy(0,0);
					LCD_putnum(hr,2);
					LCD_gotoxy(3,0);
					LCD_putnum(min,2);
			LCD_gotoxy(3,0);
			LCD_putnum(min,2);
But before that you have to make lcd.h file. Its codes are given also here. This Header is specially made for this program.
//lcd.h
#ifndef __LCD_H__
#define __LCD_H__
#define LCD_data P2
void _LCD_busy(void);
void _LCD_sdelay(void);
void _LCD_poweron(void);
void _LCD_command(unsigned char);
void _LCD_senddata(unsigned char);
void _LCD_sendstring(unsigned char *);
void _LCD_putnum(int, int);
void _LCD_init(void);
void _LCD_clear(void);
sbit LCD_rs=P1^0;
sbit LCD_rw=P1^1;
sbit LCD_en=P1^2;
void LCD_busy()
    unsigned char i,j;
        for(i=0;i<50;i++)
                for(j=0;j<255;j++);
void LCD_sdelay()
    unsigned char i;
        for(i=0;i<50;i++);
void LCD_poweron()
unsigned int i;
for (i=0;i<22500; i++);
void LCD_command(unsigned char var)
     LCD_data  = var;      //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rs   = 0;        //Selected command register
     LCD_rw   = 0;        //We are writing in instruction register
     LCD_en   = 1;        //Enable H->
L
     LCD_en   = 0;
     LCD_busy();          //Wait for LCD to process the command
void LCD_putnum(int number,int width)// LCD_putnum: Implementing integer value from -99999 to 99999
   unsigned char digit;
   if (number < 0)
     LCD_senddata('-');
	 LCD_sdelay();
	 number = -1 * number;
   switch (width)
   		case 5:
			digit = '0';
			while(number >
= 10000)                // Keep Looping for larger than 10
     			digit++;                         // Increase ASCII character
     			number -= 10000;                    // Subtract number with 10
			LCD_senddata(digit);                // Put the Second digit
			LCD_sdelay();
	   case 4:
			digit = '0';
			while(number >
= 1000)                // Keep Looping for larger than 10
     			number -= 1000;                    // Subtract number with 10
			LCD_sdelay();
		case 3:
			digit = '0';
			while(number >
= 100)                // Keep Looping for larger than 10
     			number -= 100;                    // Subtract number with 10
			LCD_sdelay();
		case 2:
			digit = '0';
			while(number >
= 10)                // Keep Looping for larger than 10
     			number -= 10;                    // Subtract number with 10
			LCD_sdelay();
		case 1:
			LCD_senddata('0' + number);           // Put the First digit
			LCD_sdelay();
void LCD_sendstring(unsigned char *var)
     while(*var)              //till string ends
       LCD_senddata(*var++);  //send characters one by one
void LCD_senddata(unsigned char var)
     P2  = var;      //Function set: 2 Line, 8-bit, 5x7 dots
     LCD_rs   = 1;        //Selected data register
L
     LCD_en   = 0;
     //LCD_busy();          //Wait for LCD to process the command
void LCD_init(void)
     LCD_data = 0x38;     //Function set: 2 Line, 8-bit, 5x8 dots
     LCD_rw   = 0;        //We are writing in data register
L
     LCD_en   = 0;
     LCD_data  = 0x0C;     //Display on, Curson blinking off command
L
     LCD_en   = 0;
     LCD_data  = 0x01;     //Clear LCD
L
     LCD_en   = 0;
     LCD_data  = 0x06;     //Entry mode, auto increment with no shift
L
     LCD_en   = 0;        //Enable H->
L
     LCD_busy();
void LCD_clear(void)
L
    LCD_en   = 0;
    LCD_busy();
void LCD_gotoxy(int x, int y)//x=0..16, y= 0..1
  int dr;
  if (y==0)
  	dr=x+0x80;
  if (y==1)
    dr=x+0xC0;
  LCD_data  = dr;      //Function set: 2 Line, 8-bit, 5x8 dots
L
  LCD_en   = 0;
  LCD_busy();
#endif
Thanks a lot...
For any quarries you can contact [email protected]
Tue Oct 11 2011, 05:39 pm
You can download the following attachents
.Hex file
.H file
.C file
.DSN file
They are all in rar file. Extract them all.
Tue Oct 11 2011, 09:35 pm
@ adambose1990
good efforts
use timer for clock that will be more accurate as compare to looping
Thu Oct 13 2011, 09:21 pm
good work adambose
and i completely agree with Majoka, you must use timers for tick generation. I will be much more accurate
Fri Oct 14 2011, 10:01 pm
@Ajay Bhargav yes surely, This project is not accurate only because of the tick generation, it lags a few second in an RTC hour, I surely will follow your advice, thanks........:)
Wed Nov 02 2011, 01:50 am
Additional advice for error free timers; use timer in free running mode so that you dont have to do load operation for timers. This way your timer will always overflow at perfect intervals, no matter how late your ISR is serviced
Also use 12Mhz for best results with above method.
Thu Nov 03 2011, 05:34 pm
Thanks a lot Ajay sir...:)
Sun Nov 06 2011, 12:47 pm
You're welcome good luck for your Final Year
Fri Feb 10 2012, 03:56 pm
Its a good and lot of information on your site and good collection of information for digital 8051. thanks for sharing the information.
Fri Feb 10 2012, 04:45 pm
Hi jamewhite86, To know more digital 8051, have a look into this site : www.rsatechbook.webs.com
There is a lot not only about 8051, but also about AVR and PIC unique projects...... Have a good day...
http://rsatechbook.webs.com/
