Discussion in "Project Doubts" started by    Darshanparabbnb    Mar 26, 2018.
Mon Mar 26 2018, 07:40 AM
hello sir,
i am doing project 'control pc using tv remote using 8051'.
i searched various shops for tsop1736 but this ir sensor is not available.....
so my question is can i use tsop1738 instead of tsop1736 ?......
if yes then tell me which kind of changes i have to do........and
if not then tell me an alternative for this ir sensor.....plz help me
Mon Mar 26 2018, 09:05 PM
The tsop1736 works at 36 kHz
the tsop1736 works at 38 kHz.
Otherewise they are the same.
You will need to find a transmitter that
works at 38 kHz.
I don't know how common they are.
You will just have to try a few.
This is an old project.
Make sure PCcontrol.exe runs on your system.
PCcontrol.exe uses com1,com2 or com3.
If using a USB serial adapter you will need to re-name
the USB com port eg 'com20' in system settings.
Tue Mar 27 2018, 04:19 AM
If i found an transmitter and connects tsop1738 ....then which kind of changes i have to do in program....?? And suggest me any other tsop which i can use for 36khz
[ Edited Tue Mar 27 2018, 04:22 AM ]
Wed Mar 28 2018, 01:33 AM
This project is for a transmitter using the Philips RC5 format.
For any other type the code will need a large re-write.
The RC5 format does not specify the Infrared carrier frequency,
so modern versions my be 38KHz.
If you have a 38KHz, RC5 format remote,
the code should not need any changes.
I have to say I have a box of remotes and not one
works with any TV or DVD etc, other that the one it came with.
Don't try this project unless you are sure you have a Philips RC5 format
remote control.
These are possible modern alternatives to the TSOP1736
but check the pinout.
TSOP4136
TSOP2136
More specialised
TSOP4336
TSOP2336
TSOP4536
TSOP2536
Many PCs don't have a serial port, so you might need a
USB/serial adapter.
If you use a USB/serial adapter you don't need the
MAX232 chip in the diagram.
[ Edited Wed Mar 28 2018, 02:17 AM ]
gigyani
Thu Apr 18 2019, 02:10 AM
please send me the code for the control unit of Electroni voting machine.
Thu Apr 18 2019, 01:06 AM
asianwomenmut
writing
Sun Apr 14 2019, 10:52 PM
@hassan malik post your problem in the "General help Guidance and Discussion" forum
Sun Apr 14 2019, 05:06 PM
RAJESH MAPARi
please send me code to interface atmega32 with 24c1024 serial eeprom
Sun Apr 14 2019, 01:33 PM
hassan malik
hello sir i installed proteus 7.8 professional on window 7 ultimate and window 10 but there would be same errors onn both windows. the error is bad license key.please any one help me
Sun Apr 14 2019, 01:32 PM
hassan malik
Sat Apr 06 2019, 05:59 PM
@deshrar. Please post your question in 8051 forum
Sat Apr 06 2019, 07:43 AM
deshraj
hallo mam.. i have downloded gsm notice board code its running fine on lcd but how so send msg to the module . i mean format of password and msg.. thank you
kevinharsha
Wed Apr 03 2019, 04:38 PM
Can i see the circuit diagram for the music tone library 8051 project?
Wed Apr 03 2019, 02:45 AM
@Prudhvi. Please post your request in 8051 forum
gigyani
Thu Apr 18 2019, 01:43 AM
Deekshaaan
Wed Apr 17 2019, 03:02 PM
popli
Mon Apr 08 2019, 02:31 AM
kevinharsha
Wed Apr 03 2019, 04:33 PM
WWSIERT
Wed Apr 03 2019, 01:02 PM
Ausonagara
Mon Apr 01 2019, 10:42 AM
tutu10
Tue Mar 12 2019, 07:11 AM
Raj243
Fri Mar 08 2019, 02:08 AM
Guests: 56, Members: 0 ...
Members: 38058
Newest member: gigyani
Forum Activity
gigyani Avatar
Posted By gigyani
Thu Apr 18 2019, 02:01 AM
STATREAD:MOV A, #WTCMD ;LOAD WRITE CO...
Deekshaaan Avatar
Posted By Deekshaaan
Wed Apr 17 2019, 04:26 PM
hello i downloaded the frequency counter project f...
ExperimenterUK Avatar
Posted By ExperimenterUK
Tue Apr 16 2019, 12:23 AM
1) Can you explain what is the use of the p-n-p tr...
kevinharsha Avatar
Posted By kevinharsha
Sun Apr 14 2019, 06:26 PM
Hey! Thanks for the help! The circuit worked well ...
Fri Apr 05 2019, 10:05 PM
Here is a version for the 8051.Make sure you add d...
kevinharsha Avatar
Thu Apr 04 2019, 05:05 PM
http://www.8051projects.net/download-d231-musical-...
Wed Apr 03 2019, 10:25 PM
HiAjay is very busy with business right now so may...
kevinharsha Avatar
Wed Apr 03 2019, 04:48 PM
I had a couple of questions :-1) Can you upload a ...
Wed Apr 03 2019, 02:41 PM
Can you post your full code.Do you have a serial t...
WWSIERT Avatar
Posted By WWSIERT
Wed Apr 03 2019, 01:20 PM
that is the image
