Rickey's World :: Discussion Forums :: Discuss and Learn :: E-books and Tutorials :: 8051
"The Final Word on the 8051"By Matthew Chapman( C code for 8051 )
Tue Mar 04 2008, 11:34PM
Hii all
Book Title:"The Final Word on the 8051"By Matthew Chapman
Description:This is a book about the Intel 8051 micro-controller and its large family of descendants. It is intended to give you, the reader, some new techniques for optimizing your 8051 projects and the development process you use for those projects. It is not the purpose of this book to provide various recipes for different types of embedded projects.
Wherever possible, I have included code examples to make the discussion clearer. There are points in the book where projects are discussed as a means of illustrating the point of the given chapter. Much of this code is available on the companion disk, to use it you will need to be familiar with C and 8051 assembler since this book is not intended to be a tutorial in C or 8051 assembler. There are many fine books you can buy to learn about ANSI C. As for 8051 assembler, the best source is the Intel data book which is free from your 8051 vendor or the manual that comes with your particular assembler.
The code on the companion diskette contains the code I wrote and compiled for the book you hold in your hands. It is fully functional and has been tested. This is not to say that that the code on the diskette is ready to go into your system and be delivered as part of your projects. Some of it will require change before it can be integrated into your system.
This book will help you learn how to make the best out of the tools you have. If you only have an 8051 assembler, you can still learn from this book and use the examples, but you will have to decide for yourself how to implement the C language examples in assembler. This is not a difficult task for anyone who understands the basics of C and the 8051 assembler set.
If you have a C compiler for the 8051, then I congratulate you. You have made an excellent decision in your use of C. You will find that your project development time using C is lower and that your maintenance time using C is also lower. If you have the Keil C51 package, then you have made an excellent decision in 8051 development tools. I have found that the Keil package for the 8051 provides the best support. The code in this book directly supports the Keil C extensions. If you have one of the other development packages such as Archimedes or Avocet, you will find that this book is still of great service to you. The main thing to be aware of is that you may have to change some of the Keil specific directives to the appropriate ones for your development tools.
In many places in this book are diagrams of the hardware on which the example code runs. These are not intended to be full schematics, but are merely block diagrams that have enough information to allow you to understand how the software must interface to the hardware.
You should look upon this book as a learning tool rather than a source of various system designs. This is not an 8051 cookbook, but rather an exploration of the capabilities of the 8051 given proper hardware and software design. I prefer to think that you will use this book as a source of ideas from which your designs springboard and grow in a marvelous world of sunshine and roses! Seriously, though, I think you will gain useful knowledge from this book that will help you greatly improve your designs and make you look like your company's 8051 guru.
http://rapidshare.com/files/38315491/19BEF9AD-C1CE-47F5-A479-2946672AE17D.rar
Password:
books_for_all
Thanks
Nisar Ahmed (Pakistan)
Deptt:R & D
 RUSHI D.
dtechnology
Thu Feb 05 2009, 08:25PM
Registered Member #14944
file not found
please re-upload
Fri Feb 06 2009, 06:57AM
Plz download from here
http://rapidshare.com/files/123384695/The_Final_Word_on_the_8051.rar
Regards
rajapolimera
Tue Jun 02 2009, 01:42AM
Registered Member #14271
pass please
Tue Jun 02 2009, 02:27AM
Download Link;
http://rapidshare.com/files/123384695/The_Final_Word_on_the_8051.rar.html
Password= mbandala
