Discussion in "Project Addition or Changes" started by    Praneeth1299    Apr 10, 2018.
Tue Apr 10 2018, 09:16 AM
Hi,
I'm generating constant frequency of 1hz and variable frequency from 1hz to 10hz frequencies, using lpc214x MCU, but not able to get the pwm output of 0.01hz frequency, and is it possible to measure the same frequency in oscilloscope?
Please suggest.
Thank you
Tue Apr 10 2018, 06:12 PM
The lpc214x has a 32-bit prescaler , so I would expect 0.01hz
to be possible, but very coarse.
What is it for ?
How close can you get, can you post your code ?
0.01hz gives a period of 100 seconds, a stopwatch would be more use than
an oscilloscope.
Fri Apr 27 2018, 11:38 AM
Sorry for the delayed response sir, Below is the code which generates 1hz constant frequency, please find the attached code of 1hz pwm generation.
That generates 1hz frequency using prescaler value, actually I need to generate 9.62hz
frequency, i'm getting 9.6hz now, but to generate 9.62hz I need resolution of 0.02, so I asked for 0.01hz pwm generation..
Thank you
Fri Apr 27 2018, 07:12 PM
The code did not attach.
Try zipping it first.
Sat Apr 28 2018, 06:30 AM
Please find the attached zip code.
Sat Apr 28 2018, 06:32 AM
Attached code main.c only..
Sat Apr 28 2018, 08:22 PM
Nice to see lots of comments.
It makes it much easier to understand the code.
Why are you setting the pre-scaler to 1mS ?
Choose a pre-scaler value that gives you the 0.01 Hz precision you want .
You could just leave it a 60MHz.
[ Edited Sat Apr 28 2018, 08:44 PM ]
Mon Apr 30 2018, 03:38 PM
Yes sir checking the frequency by setting the prescaler value for 0.01hz,
will try setting the value correctly again.
Thank you
Thu Mar 14 2019, 08:44 PM
We don't send code,but you can ask for help in the 8051 forum
Thu Mar 14 2019, 11:00 AM
Jui Sanjay Kapare
Hello sir, I want code of interfacing DS18B20 with 8051.plz send the code as early as possible
Mon Jan 07 2019, 03:31 AM
@REVOCATUS please post in the AVR forum
Mon Dec 24 2018, 09:25 AM
REVOCATUS MATEMU
sorry I mean referee boards for player substitution
Mon Dec 24 2018, 09:24 AM
REVOCATUS MATEMU
hi am.looking how to build referee by using Atmega 328 and its codes
Sat Dec 15 2018, 01:45 PM
Arslan ayoub
Hii ,, can I get the simulation of numeric keypad lock on proteus
Mon Dec 03 2018, 05:17 PM
Please post questions in the forum. The chat box is for chat
Mon Dec 03 2018, 06:43 AM
help!me!
help! I don't understand busy flag!
Sun Dec 02 2018, 08:01 PM
ile
hello
Mon Nov 12 2018, 05:58 AM
Pavan_user
i have seen your replica of I2C programming using AT89C51 but i am unable to understand the "ack_bit" variable usage ...looks like it is always 1...can you elaborate how acknowledgment is working....
tutu10
Tue Mar 12 2019, 07:11 AM
Raj243
Fri Mar 08 2019, 02:08 AM
bharatsb
Thu Mar 07 2019, 04:34 PM
Yass7
Thu Mar 07 2019, 03:55 PM
mashabed
Mon Mar 04 2019, 11:08 PM
AccelMotion
Tue Feb 26 2019, 06:06 PM
turbovps
Mon Feb 25 2019, 06:26 AM
the_Doker
Thu Feb 14 2019, 02:21 PM
Guests: 39, Members: 0 ...
Members: 38052
Newest member: tutu10
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Sun Mar 24 2019, 09:52 PM
Counting pulses is as simple asvoid interrupt isr(...
Ansh12 Avatar
Posted By Ansh12
Sat Mar 23 2019, 05:08 PM
Using the external interrupt on pin B0 is the best...
Fri Mar 22 2019, 09:10 PM
Ansh12 Avatar
Posted By Ansh12
Fri Mar 22 2019, 03:45 PM
I have pic16f877a and MPLABX8 and I want to count ...
Wed Mar 13 2019, 02:32 AM
HiI looked at" Atmel AVR042: AVR Design Considera...
tutu10 Avatar
Posted By tutu10
Tue Mar 12 2019, 07:13 AM
Hi...My firmware upgradable code lock seems to be ...
Yass7 Avatar
Posted By Yass7
Sat Mar 09 2019, 12:52 AM
It's exactly that ! it's my teacher who asked me t...
Sat Mar 09 2019, 12:27 AM
As I understand it, you want to use a P89LPC952 /...
Sat Mar 09 2019, 12:21 AM
After you get the string what do you want to do wi...
bharatsb Avatar
Posted By bharatsb
Thu Mar 07 2019, 04:40 PM
help me to write code for 8051 to receive string ...
