Discussion in "Project Doubts" started by    Sudhansudeep    Aug 31, 2018.
Fri Aug 31 2018, 06:09 PM
Shall I use the program as it is given with out any changes? And Can I use the same program for 16x4 LCD sir?
Fri Aug 31 2018, 08:41 PM
Status messages over 16 chars will need to be trimmed to 16 chars.
You will need to modify the LCD display routine to start a new line
after every 16 chars.
You will have to change 'Mob_no' to match your mobile.
unsigned char code Mob_no[]= "9739317976";
http://www.8051projects.net/download.php?view.248
[ Edited Sat Sep 01 2018, 01:25 AM ]
Sat Sep 01 2018, 05:58 AM
Thank you sir I have understood that I have to change the mobile number and have to give my mobile number which I will be using. But I did not understand the concept that u have stated regarding the LCD display to trimm to 16 chars will u please tell me which line of the program to change it to 16 chars
Sun Sep 02 2018, 09:46 PM
Okay.. I assumed the project would use all 4 lines.
In fact it only uses 2, so I wonder why a 4 line display is used.
The project will only safely display message up to 10 bytes long,
which is odd, but means no changes are needed for a 16 * 4 or 16* 2 display.
Simple changes allows 16 /20 char messages.
Add
#define LCDWIDTH 16 //or 20
unsigned char store[LCDWIDTH+1];
change store_msg()
void store_msg(unsigned char msg_array[])
unsigned char i,j;
i=59;
j=0;
	while(msg_array[i]!='\r')  // copy to end of line or buffer full
 	 store[j]= msg_array[i];
	i++;
	j++;
	if( j >
=LCDWIDTH) break;  //stop at 16 / 20
	store[j]= 0; //terminate the string
  return;
Also change clear_mybuff() as buffer is declared as 20 bytes
void clear_mybuff()
	unsigned int a;
	for(a=0;a<20;a++)
		MyBuff[a]=0x00;
[ Edited Sun Sep 02 2018, 09:52 PM ]
Mon Sep 03 2018, 02:23 AM
Ok sir I understood just I need to change the number 20 with 16 right?
Mon Sep 03 2018, 03:02 AM
change store_msg()
Shall I need to write the above lines also??
Mon Sep 03 2018, 08:47 PM
This version supports 16 character messages on 16*4 or 16*2 LCDs
[ Edited Mon Sep 03 2018, 08:55 PM ]
Tue Sep 04 2018, 03:01 PM
sir i have compiled the above program i am getting the following error
LENGTH:006H
ERROR L105: PUBLIC REFERS TO IGNORED SEGMENT
SYMBOL: MSG1
SEGMENT:?ID?GSMKEIL3
program size: data=176.5 xdata=0 code=1909
target not created
Tue Sep 04 2018, 04:16 PM
please sir can u help me in removing this error as i am using a kiel uvision 3 software as i have to complete my project in few days
Tue Sep 04 2018, 06:49 PM
Have you made any changes to the code I posted ?
The errors might be due to the version of Keil you are using.
The best fix is to get the evaluation version of Keil 5.
It has a limit of 2K, but this project is less than 2K so will be okay.
You have to register but it is free.
https://www.keil.com/demo/eval/c51.htm
Does the original project compile ?
If so you could just use that and edit your phone number and
status messages to fit.
[ Edited Tue Sep 04 2018, 07:56 PM ]
Thu Mar 14 2019, 08:44 PM
We don't send code,but you can ask for help in the 8051 forum
Thu Mar 14 2019, 11:00 AM
Jui Sanjay Kapare
Hello sir, I want code of interfacing DS18B20 with 8051.plz send the code as early as possible
Mon Jan 07 2019, 03:31 AM
@REVOCATUS please post in the AVR forum
Mon Dec 24 2018, 09:25 AM
REVOCATUS MATEMU
sorry I mean referee boards for player substitution
Mon Dec 24 2018, 09:24 AM
REVOCATUS MATEMU
hi am.looking how to build referee by using Atmega 328 and its codes
Sat Dec 15 2018, 01:45 PM
Arslan ayoub
Hii ,, can I get the simulation of numeric keypad lock on proteus
Mon Dec 03 2018, 05:17 PM
Please post questions in the forum. The chat box is for chat
Mon Dec 03 2018, 06:43 AM
help!me!
help! I don't understand busy flag!
Sun Dec 02 2018, 08:01 PM
ile
hello
Mon Nov 12 2018, 05:58 AM
Pavan_user
i have seen your replica of I2C programming using AT89C51 but i am unable to understand the "ack_bit" variable usage ...looks like it is always 1...can you elaborate how acknowledgment is working....
tutu10
Tue Mar 12 2019, 07:11 AM
Raj243
Fri Mar 08 2019, 02:08 AM
bharatsb
Thu Mar 07 2019, 04:34 PM
Yass7
Thu Mar 07 2019, 03:55 PM
mashabed
Mon Mar 04 2019, 11:08 PM
AccelMotion
Tue Feb 26 2019, 06:06 PM
turbovps
Mon Feb 25 2019, 06:26 AM
the_Doker
Thu Feb 14 2019, 02:21 PM
Guests: 46, Members: 0 ...
Members: 38052
Newest member: tutu10
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Sun Mar 24 2019, 09:52 PM
Counting pulses is as simple asvoid interrupt isr(...
Ansh12 Avatar
Posted By Ansh12
Sat Mar 23 2019, 05:08 PM
Using the external interrupt on pin B0 is the best...
Fri Mar 22 2019, 09:10 PM
Ansh12 Avatar
Posted By Ansh12
Fri Mar 22 2019, 03:45 PM
I have pic16f877a and MPLABX8 and I want to count ...
Wed Mar 13 2019, 02:32 AM
HiI looked at" Atmel AVR042: AVR Design Considera...
tutu10 Avatar
Posted By tutu10
Tue Mar 12 2019, 07:13 AM
Hi...My firmware upgradable code lock seems to be ...
Yass7 Avatar
Posted By Yass7
Sat Mar 09 2019, 12:52 AM
It's exactly that ! it's my teacher who asked me t...
Sat Mar 09 2019, 12:27 AM
As I understand it, you want to use a P89LPC952 /...
Sat Mar 09 2019, 12:21 AM
After you get the string what do you want to do wi...
bharatsb Avatar
Posted By bharatsb
Thu Mar 07 2019, 04:40 PM
help me to write code for 8051 to receive string ...
