Discussion in "Project Help" started by    Ansh12    Mar 22, 2019.
Fri Mar 22 2019, 09:15 pm
I have pic16f877a and MPLABX8 and I want to count pluses generated by incremental encoder
for example : I want to count 40000 pulses
I see we can count pulses with an interrupt
1 which interrupts would to use to count encoder pulses timer or external interrupt?
2. Is there any better option?
[ Edited Fri Mar 22 2019, 09:30 pm ]
Sat Mar 23 2019, 02:40 am
Using the external interrupt on pin B0 is the best option.
 Ansh12 like this.
Sat Mar 23 2019, 10:38 pm
Thank's ExperimenterUK
Here is code for external interrupt I don't have an idea how to make progress for counting pulses
// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = ON        // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#define _XTAL_FREQ 16000000
#include <xc.h>
void main(void)
    TRISB0=1;     // Make RB0 pin as input
    TRISD1= 0;    // Make RD1 pin as output
    OPTION_REG=1;  // Set Rising Edge Trigger
    INTCON = 1;   // Enable The Global Interrupt
    INTE = 1;     // External Interrupt Enable
    return;
void interrupt isr(void)
    if(INTF==1)
        INTF = 0;  // Clear interrupt flag
any help with programming would be appreciated ?
Mon Mar 25 2019, 03:22 am
Counting pulses can be as simple as
if(INTF==1)
pulseCount++;
declare pulseCount in the body of you program as for example
volatile unsigned int pulseCount; //0- 64000
void main(void)
pulseCount=0;
.......etc
Really it depends on what you are doing with the count.
In the latest version of MPLAB IDE (v5.15) you need to declare the interrupt handler as
__interrupt() void isr(void)
if(INTF==1)
pulseCount++;
[ Edited Tue Mar 26 2019, 10:25 am ]
Sun Mar 31 2019, 03:26 pm
Following code are not working
if 30 count complete turn on / off LED
// CONFIG
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#define _XTAL_FREQ 20000000 //Specify the XTAL crystal FREQ
#include
volatile unsigned int Counter;
char Trigger;
void main(void)
    INTE = 1;     // External Interrupt Enable (not INTF)
    GIE=1;
    Counter = 0;  //initial values at start up
    Trigger = 0;
    while (1)
        if(Trigger == 1)
             Trigger = 0;
             Counter = 0;
             RD1 = 1;  // LED ON
             __delay_ms(1000); //
             RD1 = 0;  // LED OFF
             __delay_ms(500);
    if(INTF==1)
        Counter++;    // add 1 to the Counter
        if(Counter == 30)
        Trigger = 1;
after some time led goes turn on and staying turn on
can you tell me why it's staying on
Mon Apr 01 2019, 02:03 am
I tried your code in Proteus and it works.
How are you driving B0 ?
How fast are you driving B0 ?
How long before the LED comes on ?
[ Edited Mon Apr 01 2019, 02:09 am ]
Mon Apr 01 2019, 05:04 pm
I have incremental encoder of 5000 PPR. encoder work on 24V DC so I have converted output of encoder into 5V DC using opt-coupler
When I burned program LED stay on for forever
Please find attachment
Tue Apr 02 2019, 12:41 am
The problem may not be with your code.
You will have to go back to basics and test what works.
So..first write program to just flash the led on and off.
Then flash the led when you get any input on B0.
Disconnect the encoder and change level by hand.
Let me know what happens.
 Ansh12 like this.
Mon Apr 22 2019, 02:42 pm
as suggested I have modified program but I don't know why LED doesn't flash when sensor become high
// CONFIG
#include<xc.h>
char Trigger;
void main(void)
    PORTD = 0b00000000; //
    TRISB=0b00000001;     // Make RB0 pin as input
    TRISD= 0b11101111  ;    // Make RD1 pin as output
    GIE=1;
    while (1)
    if(INTF==1)
         RD4 = 1;  // LED ON
         RD4 = 0;  // LED OFF
         INTF = 0;
Fri Apr 26 2019, 01:50 am
I made a minor change, it works in Proteus.
Try the attached hex code, just in case you have a compiler problem.
Are you sure you are getting a good signal into pin RB0 ?
if(INTF==1)
         RD4 = 1;  // LED ON
         RD4 = 0;  // LED OFF
         INTF = 0;
