Discussion in "Project Help" started by    WWSIERT    Apr 3, 2019.
Wed Apr 03 2019, 01:18 PM
I am feeding the GPS signal into a 8051 microcontroller via GT-7U gps.
My code does not detect the header $GPRMC, the image below shows some
of the characters I m receiving. The received chars don't seem valid
and I don't know what I should change to correct this...
void receive_data() interrupt 4
info[check++]=SBUF; //Read SBUF
lcd_data(info[check-1]);
if(check<7) //Condition to check the required data
if(info[check-1]!=test[check-1])
check=0;
RI=0;
void serial()
EA=1;
ES=1;
SCON=0x50 ; // SERIAL MODE 1 ,8- BIT DATA ,1 STOP BIT ,1 START BIT
, RECEIVING ON
TMOD=0x20; //MODE=2
TH1=0xFD; // 9600 BAUD
TR1=1; //TIMER START
//IE=0x90; // enable interrupts...
void lcd_data(unsigned char item)
port2 = item;
rs= 1;
rw=0;
e=1;
delay(50);
e=0;
return;
Wed Apr 03 2019, 01:20 PM
that is the image
Wed Apr 03 2019, 02:41 PM
Can you post your full code.
Do you have a serial to USB adapter ?
If not, get one, they are very useful for this sort of project.
If you have one, use it to connect your GPS to your PC to test its output.
You can then connect the PC to your 8051 to test its response to known characters.
[ Edited Wed Apr 03 2019, 10:31 PM ]
Mon Jun 17 2019, 05:33 PM
charmdateapc
cooking
Sun Jun 16 2019, 07:48 PM
hanoch Taub
i need to interface sim800 to 8051, the problem is that on the module sim800 there are 9 pins connector and I don't know how to connect him to 8051, which pins to tx and rx on 8051 module sim there is
Tue May 28 2019, 07:14 PM
Ron Otsig
KBI does not work on P89LPC920 but it works on P89LPC925
Mon May 27 2019, 09:03 AM
BIJI MATHEW
Hello friends....
DragonDad
Tue May 21 2019, 03:02 PM
Hi. Who is online?
Tue May 14 2019, 12:38 AM
Jayson Contreras
Hello
Xkalebar
Sun Apr 28 2019, 09:06 AM
Please provide me the code for gsm based sms controlled notice board
Sun Apr 14 2019, 10:52 PM
@hassan malik post your problem in the "General help Guidance and Discussion" forum
Sun Apr 14 2019, 05:06 PM
RAJESH MAPARi
please send me code to interface atmega32 with 24c1024 serial eeprom
Sun Apr 14 2019, 01:33 PM
hassan malik
hello sir i installed proteus 7.8 professional on window 7 ultimate and window 10 but there would be same errors onn both windows. the error is bad license key.please any one help me
Easwaran22
Thu Jun 13 2019, 10:16 AM
JenniferJJ
Thu Jun 13 2019, 05:12 AM
seyoonnet
Tue Jun 04 2019, 12:37 PM
Charbel
Sun Jun 02 2019, 03:30 PM
ronotsig
Mon May 27 2019, 03:00 AM
WilsonNig
Sun May 26 2019, 03:11 AM
DragonDad
Tue May 21 2019, 02:50 PM
dhiyamtech
Thu May 09 2019, 10:20 AM
Guests: 46, Members: 0 ...
Members: 38072
Newest member: Easwaran22
Forum Activity
JenniferJJ Avatar
Posted By JenniferJJ
Thu Jun 13 2019, 05:17 AM
Hi,Hello Members,I am the newbie member, I like ve...
ExperimenterUK Avatar
Posted By ExperimenterUK
Thu May 30 2019, 08:32 PM
It occurs to me that although the P89LPC921 and P8...
Wed May 29 2019, 09:05 PM
I would suggest a fresh approach.The Keil compile...
ronotsig Avatar
Posted By ronotsig
Wed May 29 2019, 03:13 PM
Since the code works for the P89LPC925, it is appa...
Mon May 27 2019, 06:23 PM
I can't see any reason that those registers would ...
ronotsig Avatar
Posted By ronotsig
Mon May 27 2019, 03:06 AM
I am trying to using P89LPC921 or P89LPC922 in a p...
Ansh12 Avatar
Posted By Ansh12
Sun Apr 28 2019, 02:15 PM
I made a minor change, it works in Proteus.Try the...
Thu Apr 25 2019, 08:20 PM
gigyani Avatar
Posted By gigyani
Thu Apr 25 2019, 01:17 AM
when i add cufirst.hex its not working.after 2-3 s...
Wed Apr 24 2019, 12:29 AM
http://www.8051projects.net/download-d205-electron...
