Discussion in "Project Help" started by    AdiGhazi    Jun 18, 2019.
Tue Jun 18 2019, 11:20 AM
Hlo Dear ,
I've to program AT89C51AC3 RT-LUM using flip but I'm getting time out error for RS232.
Will you please suggest me which programmer will be supportable to program this Chip.
Thank you and have a great day!
Tue Jun 18 2019, 10:19 PM
Okay.. I have never programmed the AT89C51AC3 or used Flip,
so if anyone has any ideas, please post.
How are you connecting to the AT89C51AC3
and at what baud rate ?
Thu Jun 20 2019, 05:24 AM
Dear,
I'm using RS232 serial port cable to use flip and baud rate is 9600 at stop bits of 2.
Thu Jun 20 2019, 10:08 PM
AdiGhazi
The usual setting of a serial port is, 1 Start bit, 8 data bits , no parity and 1 stop bit.
The output of a PC serial port is around plus and minus 12 volts.
How are you connecting to the micro ?
Is it on a development board?
Sat Jun 22 2019, 01:26 PM
I’ve use the AT89C51ED2 which has a similar programming procedure.
Data for programming the AT89C51AC3 is at:
http://ww1.microchip.com/downloads/en/DeviceDoc/doc4386.pdf
The baud rate is specified as 8 data, no parity, 2 stop bits with auto-baud detection.
The tricky bit is starting the boot-loader on the AT89C51AC3 which involves taking PSEN low while the device is reseting.
Typically there will be two buttons, one for RESET and one for PSEN (which may be called the boot-loader button, program button or something else).
The procedure is:
Power up the device.
Press and hold the RESET button.
Press and hold the PSEN button.
Release the RESET button.
Release the PSEN button.
This should start the boot-loader which will wait for a “U” on the serial port to perform the auto-baud detection.
To test the physical connection (to make sure you are using the correct comm port and it is wired correctly) use a terminal program that simply sends keystrokes to the serial port and displays any characters returned. After following the procedure above to start the boot-loader typing “U” should cause the device to detect the baud rate and transmit “U” back.
Once you are sure the boot-loader and connection are both working OK you can try FLIP again.
Tue Jan 14 2020, 07:08 AM
shubham kharade
when i am trying to simulate the program in Proteus 8 professional, I am getting some errors as cannot find module file dhtxx.md can u help me
Tue Dec 17 2019, 01:44 PM
Devangi
hello..i am programming industrial timer using 8051 with 24lc64 eeprom. i have query in storing the 3 diff value in eeprom with enter button. can anyone share c code ?
Tue Dec 17 2019, 10:30 AM
Andrius
Hello. Can anyone share the code in Bascon and scheme in Proteus?
Thu Nov 21 2019, 12:30 PM
raj2555
Sat Oct 12 2019, 10:23 PM
Sat Oct 12 2019, 10:18 AM
Bhadra Sajikumar
Mon Sep 23 2019, 07:37 AM
Nathaniel
Wed Sep 18 2019, 08:48 PM
Caryn Kover
Thank you for your time,
Mon Aug 05 2019, 07:09 PM
Mon Aug 05 2019, 04:33 PM
Ismail balghmi
Nippy56
Sun Jan 19 2020, 02:13 AM
usb5962
Sat Jan 11 2020, 10:42 AM
elt
Tue Jan 07 2020, 06:53 PM
mg3914697
Tue Jan 07 2020, 12:42 PM
afds43
Sun Dec 29 2019, 05:54 AM
Rupeshpatil
Fri Dec 27 2019, 06:14 PM
pyxus
Sat Dec 14 2019, 12:31 PM
Istika
Thu Dec 12 2019, 12:04 PM
Guests: 28, Members: 0 ...
Members: 38116
Newest member: Nippy56
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Fri Jan 17 2020, 10:24 PM
We will need the circuit diagram.A Proteus simulat...
Billz Avatar
Posted By Billz
Sat Jan 11 2020, 05:43 PM
hi everyone please attached files are my c code fo...
Tue Jan 07 2020, 08:18 PM
Not a stupid question.Setting up "Eclipse" can be...
elt Avatar
Posted By elt
Tue Jan 07 2020, 07:06 PM
So i have just began learning programming micros a...
Billz Avatar
Posted By Billz
Mon Jan 06 2020, 09:22 PM
I think it would be better if you guys try to come...
Mon Jan 06 2020, 12:22 AM
Can you post a circuit diagram and any code you ha...
Billz Avatar
Posted By Billz
Sun Jan 05 2020, 08:17 PM
Need help regarding C code (specifically for PIC 1...
Mon Dec 30 2019, 06:42 PM
Can you give more details of your problem.
Rupeshpatil Avatar
Posted By Rupeshpatil
Fri Dec 27 2019, 06:21 PM
How to copy program my old microcontroller to new ...
ilylily07 Avatar
Posted By ilylily07
Thu Dec 12 2019, 02:26 PM
wil do.thank you for your advice!
