Discussion in "Electronics" started by    3AAPC    Jul 21, 2019.
Sun Jul 21 2019, 12:47 AM
With the GPS antenna in the outdoors, I use the ublox software to view my coordinates. After I set the baud rate and other options settings for the GPS module. However, only the time can be displayed in the Text Console and no other information can be displayed.
After that, I used the software recovery settings to recover the GPS module. But this still has no effect.
But when I measured the GPS TX pin with an oscilloscope, I found a square wave signal of about 3v. Can view the picture below
Has anyone encountered such a situation, how can I solve it?
Sun Jul 21 2019, 12:51 AM
Wed Jul 24 2019, 10:42 PM
Your unit is communicating, so I assume the GPS signal is just not good enough.
Check your aerial connection.
Try the aerial flat, on edge etc.
Try moving further from surrounding buildings, trees etc that might block the signal.
Getting a lock the first time can take a while, leave it at least 30 minutes.
Mon Jan 27 2020, 09:00 PM
James Dillon
>>>https://fasttrafficsolutions.xyz
Wed Jan 22 2020, 06:16 PM
MINU CHAUDHARY
Tue Jan 14 2020, 07:08 AM
shubham kharade
when i am trying to simulate the program in Proteus 8 professional, I am getting some errors as cannot find module file dhtxx.md can u help me
Tue Dec 17 2019, 01:44 PM
Devangi
hello..i am programming industrial timer using 8051 with 24lc64 eeprom. i have query in storing the 3 diff value in eeprom with enter button. can anyone share c code ?
Tue Dec 17 2019, 10:30 AM
Andrius
Hello. Can anyone share the code in Bascon and scheme in Proteus?
Thu Nov 21 2019, 12:30 PM
raj2555
Sat Oct 12 2019, 10:23 PM
Sat Oct 12 2019, 10:18 AM
Bhadra Sajikumar
Mon Sep 23 2019, 07:37 AM
Nathaniel
Wed Sep 18 2019, 08:48 PM
Caryn Kover
Thank you for your time,
wounder
Sat Jan 25 2020, 12:09 PM
brucewilliams20
Thu Jan 23 2020, 11:47 AM
Nippy56
Sun Jan 19 2020, 02:13 AM
usb5962
Sat Jan 11 2020, 10:42 AM
elt
Tue Jan 07 2020, 06:53 PM
mg3914697
Tue Jan 07 2020, 12:42 PM
afds43
Sun Dec 29 2019, 05:54 AM
Rupeshpatil
Fri Dec 27 2019, 06:14 PM
Guests: 67, Members: 0 ...
Members: 38118
Newest member: wounder
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Sun Jan 26 2020, 04:05 AM
For a 12MHz crystal using a normal divided by 12 c...
wounder Avatar
Posted By wounder
Sat Jan 25 2020, 12:14 PM
I have a 8051 micro controller ,it has timer0,1,2,...
brucewilliams20 Avatar
Posted By brucewilliams20
Sat Jan 25 2020, 08:25 AM
Also, does anyone knows a platform where I can liv...
Sat Jan 25 2020, 08:17 AM
Hi Mirza,That match and the politics, both are fin...
Fri Jan 17 2020, 10:24 PM
We will need the circuit diagram.A Proteus simulat...
Billz Avatar
Posted By Billz
Sat Jan 11 2020, 05:43 PM
hi everyone please attached files are my c code fo...
Tue Jan 07 2020, 08:18 PM
Not a stupid question.Setting up "Eclipse" can be...
elt Avatar
Posted By elt
Tue Jan 07 2020, 07:06 PM
So i have just began learning programming micros a...
Billz Avatar
Posted By Billz
Mon Jan 06 2020, 09:22 PM
I think it would be better if you guys try to come...
Mon Jan 06 2020, 12:22 AM
Can you post a circuit diagram and any code you ha...
