Discussion in "New Ideas regarding projects" started by    mckunatz    Jul 13, 2008.
Sun Jul 13 2008, 08:24 am
i am jst a newbie about this project thats why i need help(s) about the necessary to be done to built this project successfully..
more details....
more outputs...
more sample...
more descriptions..
tnx a lot...
Sun Jul 13 2008, 12:22 pm
more patientance.........
Arun
Mon Jul 14 2008, 08:09 pm
good answer arun
anyways.. first select a phone or GSM modem you are going to use.. only then you can move forward with more details and whatever stuff you asked for
Wed Jul 16 2008, 06:46 pm
i plan to use the cheapest phone the nokia 3315.. :-) is it compatible for this device to the project?if not.. can you recommend me other phone type?
Wed Jul 16 2008, 06:48 pm
sir, after this step..wat are d next steps to be done?
Wed Jul 16 2008, 08:15 pm
well it does not have at commands. and i think you can use it. if it has same protocol as 3310,
download PDU converter from download section and see if you're able to send sms or not.
Thu Jul 17 2008, 03:26 pm
I'd advise you to use a GSM-modem where you can use the AT-comandsyntax (eg. the MTC45 GSM-module).
And I wouldn't use SMS-based switching. I'd use DTMF, that's very easy. You only need a DTMF-receiver like the MT8870D. Then you can (for example) call your GSM-module enter the pin and turn the light on by pressing 11# ore something else.
[ Edited Thu Jul 17 2008, 03:26 pm ]
Thu Jul 17 2008, 03:41 pm
thank you sir,.i appreciate ur advise... but i want to build this sms based device switching which is i already proposed.. i need to work on it until i finish it.. but ican not make it without ur helps sir.. yah, i have a 3310 unit too. how i shud i do it..??
Thu Jul 17 2008, 04:04 pm
http://www.8051projects.info/files/smss.GIF
http://www.8051projects.info/files/smss1.GIF
sir please check this link.. i want to do this schematic diagram but i dont have yet any information to this circuit.. can u explain further details to thid circuit..??? tenk you sir..
Thu Jul 17 2008, 04:10 pm
http://www.8051projects.info/images/IMAG0076.JPG
in this project sir.. they used nokia 5110.. how is this sir?? is it the same with that cicuit i mentioned above..??
tenks a lot for the helps sir...
HenryLaf
Mon Apr 22 2024, 03:50 pm
bleradrar
Mon Apr 22 2024, 06:38 am
ppu-pro_ka
Sun Apr 21 2024, 07:39 pm
Infewow
Sun Apr 21 2024, 06:30 pm
HumanTak
Sun Apr 21 2024, 12:26 pm
Zacharybus
Sun Apr 21 2024, 02:45 am
