rtc interfacing
Tue Aug 07 2007, 10:04 am
hello rickey,
I have programmed the init code as function in the main code and checked the output, but i got the same old results. I think its time recheck the rtc , is there any essy way to do it. suggest me.
Tue Aug 07 2007, 04:50 pm
are you still getting the same data without any change? also do one thing.. put some delay in sending the data to terminal.
can you attach your code again? i want to take a look.
Thu Aug 09 2007, 10:35 am
hello ajay,
i have introduced the delay in the code as per your suggstion and the code but no change in the result. the code is attached herewith
Thu Aug 09 2007, 02:41 pm
venkat i still don't see the code :-|
are u still not sure how to attach it?
ok.. read this carefully..
in the bottom right or top right of the forum you have a "Post Reply" button.
click on it.. you will get a form.. in which you've place to write your message.. and there is a place to attach file.
so.. click on browse button to select the file and then click on reply to thread button on that page. your file will get attached automatically.
