T230 direct interfacing with microcontroller
Thu Aug 16 2007, 07:02 pm
i am seriously not sure.. because USB.. well yeah modem is there in Z550i... but are USB operated not serial. so might be changes in configuration.
I think this page might be of some help to you..
Sony Ericsson Docs and tools for developers
Thu Aug 16 2007, 08:20 pm
i saw the pdf files they r gud.why the modem wont work if we convert rs232 to USB signals.Does it need handshaking signals.
Fri Aug 17 2007, 05:28 pm
thanks for ur help friend i would definitely let u know if i get a lead
Tue Aug 21 2007, 07:44 pm
hi friend
i am planning to buy a DRS-11 serial cable for the phone.If the at commands works
then how should i interface controller with the cable.how to power up the cable?
Tue Aug 21 2007, 08:06 pm
check the cable on hyper terminal first. if it works then you can use simple RS232 interface... if possible test it on the shop so you shouldn't be wasting your money
Tue Aug 21 2007, 10:48 pm
first check it with hyper terminal if it responds you that means there is nothing more than just basic three connections are needed which are TX,RX and GND. also check the line status using some kind of serial monitor software.
Wed Aug 22 2007, 06:11 pm
hi
if i set off hardware control and try the at commands.will it work friend?
