Discussion in "Map Me Support" started by    VR6Pete    Oct 14, 2009.
Sat Oct 17 2009, 02:54 am
loads everything down to </udata> but no xml closing tag?
Wed Oct 21 2009, 01:07 pm
well that means there are no users in the list. are you sure you have enabled the location field in user-extended option?
I checked the same files on my server its working fine.
Fri Oct 23 2009, 05:56 pm
Waitin for update
Wed Nov 04 2009, 05:19 pm
I also test on VR6Pete's site
I go to Personal Info =>Miscellaneous=>Location
and enter my address , (in HongKong)
Before HongKong have 6 members, after i updated, it still 6 members.
But i just setup a XAMPP and clean install e107 and mapme , it is working.
I am still using the old version of mapme, it work everythings.
Wed Nov 04 2009, 06:09 pm
sad i still dont get it. Its working on my site. uh...
Wed Jan 20 2010, 04:44 pm
Hiya,
Sorry for the delay in replying...
it's getting stuck on "Getting a Map information from mapme_location and storing..." progress bar doesnt move.
I've ran /e107_plugins/mapme/mapxml.php?type=update and all the data is returned with no errors.
Is any updated versions I can try ?
Thanks.
pete
Tue Feb 16 2010, 08:11 pm
Here is what happens when i try the import progress, i hope it helps...
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET CLR 1.1.4322; InfoPath.2; OfficeLiveConnector.1.4; OfficeLivePatch.1.3)
Timestamp: Tue, 16 Feb 2010 14:45:14 UTC
Message: 'GClientGeocoder' is undefined
Line: 108
Char: 6
Code: 0
URI: http://www.vr6oc.com/e107_plugins/mapme/admin_config.js
Wed Feb 17 2010, 01:38 am
this error should not come.
Try to reload the page and then wait for sometime before you start updating. I check the script its fine, you can compare this the one on my site.
http://www.8051projects.net/plugins/mapme/admin_config.js
Wed Feb 17 2010, 07:40 pm
I know it should not come, and it should work, but it doesnt, there is a problem somewhere.
I can give you admin access to my site and you can see for yourself if you want because nothing is getting resolved in its current state
Are there any newer version from the last beta version I used last time?
Thanks.
Pete
Thu Feb 18 2010, 06:10 pm
nope there is no new version..
what time can you come to chat? (GMT time)
so i can finally release a new finished version?
