GreenBee Project
Sun Oct 02 2011, 12:04 pm
I do not have any errors or warnings.
Because i do not have REAL hardware to test and have YET TO design a PROTEUS design.
I wondered u might have a fast glance and let me know the PROBABLE mistakes i have written so far.
I am very bad at coding. am a noob. and there might be Code Optimisations or easier ways of writing the code.
Sun Oct 02 2011, 02:47 pm
@ firoz3321
if it is working is proteus with no problem then i think ur code is ok
its not bad it is better as i think
u handle things in right way
obviously logic manner changes as time pass and u get experience
u can use custom function as compare to printf
printf is an easy way for us but eat too much ram and ROM
but atmega has sufficient ram and ROM
so no worry about that
so it is ok i think
so it is ok i think
Fri Nov 25 2011, 08:09 pm
Hey, Feroze, I tried to run the Hex file, which was in the GreenBee version2's CODES folder... But My LCD is showing only black boxes...and nothing else!!!
Kindly suggest something ASAP!
I tried the variable resistor, but it's still not working
Fri Nov 25 2011, 08:17 pm
Make sure all your hardware connections are correct.
Test the LCD with a sample code to make sure the LCD actually works.
For connections refer:
http://www.8051projects.net/lcd-interfacing/
