Discussion in "General help Guidance and Discussion" started by    pravin_35    Apr 8, 2010.
Fri Nov 12 2010, 12:29 pm
#31
good work pash
Sat Dec 04 2010, 04:48 pm
#32
NI Vision Builder for Automated Inspection (AI)
Take a tour of Vision Builder AI with this interactive demo
Vision Builder AI can help you easily configure, benchmark, and deploy a vision system that addresses vision applications from pattern matching to code reading and presence detection to precision alignment and classification.
With Vision Builder AI, you can perform the following tasks:
Acquire and process images with any NI frame grabber, NI Compact Vision System, NI Embedded Vision System, NI Smart Cameras as well as GigE Vision, IEEE 1394 cameras, and USB DirectShow cameras
Configure more than 100 powerful machine vision tools including geometric matching, optical character recognition (OCR), and particle analysis
Set up complex pass/fail decisions based on inspection results
Communicate triggering and inspection results directly over digital I/O, serial, and Ethernet protocols
Use the default deployment interface or customize your own
Vision Builder AI simplifies the development and maintenance process by replacing the complexities of programming with an interactive menu-driven development environment, without sacrificing performance or range of functionalityNI Vision Builder for Automated Inspection (AI)
Questions? Get real-time assistance now!
http://www.ni.com/vision/vbai.htm take a tour!!!!
 coolmirza143 like this.
Sat Dec 04 2010, 11:27 pm
#33
I have a question..
I understand that Labview is a test and simulation tool.
Does labview work as a code generator too? can this code be used on any controller?
i have seen videos where they build up a system and program the hardware, usually hardware is a special device not really a generic controller.
Pravin please put some light on this
Sat Dec 04 2010, 11:56 pm
#34
no ajay...labview cannot generate any code ............. i will work oly in os platform....
u can write c code in labview... it as a c complier.....
Sun Dec 05 2010, 12:01 am
#35
so what controllers are supported by this?
Sun Dec 05 2010, 12:10 am
#36
labview wont support.. fpga tools are there in labview ucan interface fpga...& also ucan communicate wit controller... through serial comm...
Sun Dec 05 2010, 12:29 am
#37
then why people are so crazy about this software? there is nothing more than just data monitoring or logging
Sun Dec 05 2010, 08:54 am
#38
ajay u can develop a graphical application..... it as variables .data types.... etc.... i will giv an intro on it
Sun Dec 05 2010, 05:32 pm
#39
sure i will wait for that
Sat Jun 16 2012, 09:56 pm
#40
dear all -
i found a little about Labview--
"LabVIEW (short for Laboratory Virtual Instrumentation Engineering Workbench) is a system design platform and development environment for a visual programming language from National Instruments."
----from wikipedia..
so its a library of virtual instruments those can be used alone or integrative manner...
you can build your own VIs by combining various VIs in your automation program...
so its a kind of Graphical controller designing for controlling your instruments....
---->further awaiting from Mr. Pravin...
