Discussion in "8051 Discussion Forum" started by    Abhinav    Jun 13, 2010.
Sun Jun 13 2010, 06:43 PM
Hi friends
i am a little confused while using AT24C04. like how many addresses are available for storing the data bytes?
The slave address is 1010 for all EEPROM'S so can we use 2 EEPROM's with one micro?
How to store values bigger that a byte in EEPROM?
i am using BASCOM for coding.
thank you all.
Sun Jun 13 2010, 07:57 PM
those are upper 4 bits of 7-bit address. the lower 3 bits are configurable which means yes you can use more than 1 rather total of 8 such EEPROMs at a time.
split them in 2 or 3 depending on how big your data is..
let say if its a 16-bit value then:
EEPROMWrite(Add, data>>8); // write first 8bits
EEPROMWrite(Add+1, data);//write next 8 bits to next address
sorry i am not good at bascom
and for your doubt regarding the subaddress/data address of EEPROM:
before you calculate the size of sub address you need to know how much memory is addressable. lets take an example of 24C02 EEPROM.
24C02 is 2kbit = 2/8 kByte = 1/4Kb = 256bytes
so to accomodate 256 addresses you need 1 byte (00 to 255). so your sub address will only be of 1 byte.
now lets take case with 24C16
24C16 is 16Kbit = 16/8Kbyte = 2Kb = 2048 bytes
so we need atleast 2 bytes to accomodate 2048 addresses. so sub address now will be of 2 bytes in this case.
so you can see how we decide the internal data addresses of EEPROM.
Tags I2C eeprom addressingEEPROM interfacing 8051I2C EEPROM internal addressingi2c eeprom sub addressHow i2c eeprom addressing works
Mon Jun 14 2010, 07:56 AM
Hi ajay
Thanks for a amazing detailed reply.
As per this website http://www.digchip.com/datasheets/parts/datasheet/054/AT24C04-10PC-1_8.php
we can connect maximum of-
AT24C01/02 = 8
AT24C04 = 4
AT24C08 = 2
AT24C16 = 1
because of their reducing hard wired addressing pins.
I cannot understand fully the meaning of below-
"AT24C04, 4K SERIAL EEPROM: Internally organized with 32 pages of 16 bytes each,
the 4K requires a 9-bit data word address for random word addressing"
as written in datasheet.
"The 4K is internally organized with 256 pages of 2-bytes each."
as described on digichip website.
thank you so much.
Mon Jun 14 2010, 02:25 PM
when addressing register there are two path, first on which page that register lies second what is the address of that register on that particular page.
you can assume MSB of address to be as page address and LSB as address of register on that page. so you can understand better what is page address and how it relates to register address.
even in 8051 we have page addressing of ram in which RAM is organized as 256 pages of 256 bytes each. so total accessible ram by 8051 is 256*256 = 65536 bytes. when interfacing external ram the page address is given by P2 and register address is given by P0. relate to it and you will understand.
Thu Jun 17 2010, 07:07 PM
hi ajay,
now i understood almost all things just one to ask that if start sending data bytes from address 0 then i think i have to send address(16) again after 16 bytes else first byte will be overwritten.
am i right ?
thanks
Thu Jun 17 2010, 07:20 PM
write operation will not work if you dont send a stop after page size limit of EEPROM.
You can see every EEPROM datasheet explains Page write operation differently from byte write operation. datasheet will provide you complete details.
Sun May 20 2018, 10:01 AM
justinb
how to write and execute a program that read the keypad button and display the number on 7 segment on intel8051 at89s52 in assembly language?
Thu May 17 2018, 06:36 AM
HAMZA TAJ
sir iwant to ask about controller of three phase supply by using back to back thyristor instead of triac....will u give me some guideline?
Sat Apr 28 2018, 12:54 PM
ashutosh jain
IR Remote Switch using TV remote (RC5 Protocol) is not working properly. opp1 & opp2 is in problem.plz help
Fri Apr 27 2018, 08:09 PM
@kaiserslautern Post in forum
Wed Apr 25 2018, 07:09 AM
kaiserslautern
Hello everyone, using software uart is a very good idea for a second serial port. Thank you so much. I would kindly like to know how to connect this port to the PC?
Sat Apr 21 2018, 07:50 PM
This is a community site. Feel free to help anyone needing advice
hareeshchamiyar
Thu Mar 29 2018, 10:47 AM
please help me for the configuration bits for dspic30f2010
hareeshchamiyar
Thu Mar 29 2018, 10:45 AM
can any one using dspic30f2010.
Thu Mar 29 2018, 06:03 AM
Neena
can anybody give solar tracking in 8051 using proteus and keil to mail [email protected]
Mon Mar 19 2018, 07:33 PM
sorry bedo.. maybe next time
bdmehta
Tue May 22 2018, 02:30 AM
kmag1953
Sun Apr 29 2018, 07:09 PM
udiwonder
Sat Apr 28 2018, 12:41 PM
pirpiri
Sat Apr 21 2018, 03:35 PM
Pater
Fri Apr 20 2018, 02:38 PM
jamiel
Sat Apr 14 2018, 12:47 AM
akrepkral76
Wed Apr 04 2018, 07:51 PM
samanthaeaves
Mon Apr 02 2018, 06:27 AM
Guests: 57, Members: 0 ...
Members: 37998
Newest member: bdmehta
Forum Activity
ExperimenterUK Avatar
Posted By ExperimenterUK
Sat Jun 16 2018, 11:33 PM
hi sir sorry for the late reply sir can we control...
LAMBO Avatar
Posted By LAMBO
Sat Jun 16 2018, 07:15 AM
Mon May 14 2018, 10:17 PM
So the main problem is that I am not getting Analo...
Mon May 14 2018, 09:40 PM
Hi sir after checking all the connection i...
Pater Avatar
Posted By Pater
Mon May 14 2018, 05:36 PM
Basically my project is based on Data Acquisition ...
LAMBO Avatar
Posted By LAMBO
Sun May 13 2018, 02:13 PM
Mon May 07 2018, 07:27 PM
This design should be fine.Choose a frequency betw...
Pater Avatar
Posted By Pater
Mon May 07 2018, 01:28 PM
Sorry for late reply as exams were on,Based on my ...
Thu May 03 2018, 03:32 PM
If the circuit works with a light bulb, the probl...
LAMBO Avatar
Posted By LAMBO
Thu May 03 2018, 08:04 AM
Hi sir as u mentioned above everthing is working...
