8051 based project That can save up to 60 codes with max of 6 combination of numbers
Thu Nov 25 2010, 07:38 AM
dear
start coding with lcd first
make ur own code that will save time as compare to edit other code
Thu Nov 25 2010, 08:33 AM
hi onyot, for me its easy to use lcd. so from now read the tutorial then ask question here f u have some doubts.. .
Fri Nov 26 2010, 08:06 AM
Do you have any tutorial on how to connect and at89c2051 or at80s52 in the PC?
Fri Nov 26 2010, 08:38 AM
hi onyot, y u want to interface 8 to pc? Do u want to use serial communication? What do u want to do now?
Fri Nov 26 2010, 08:43 AM
So if I use serial comm. what should I do? Do you have any idea? Can you invite the others so that we can have a brainstorming? ehehhehhe
[ Edited Fri Nov 26 2010, 08:44 AM ]
Fri Nov 26 2010, 08:47 AM
onyot wite your code share it with us if u have any problem then create HEX file of your code using keil...
you didn't need to connect or interface your controller to PC!!! you are going to use LCD and in this case you have to interface LCD with 2051 or 8051 no need of PC interface.....
after creating you HEX file then you need a PC to BURN you code in you controller and it takes less that a minute
and if u wanna connect your PC then use UART....first write code for LCD check it and then proceed to serial communication.....
Fri Nov 26 2010, 10:20 AM
dear
concentrate on one thing then go to next
anyhow this is tutorial of serial port
http://www.8051projects.net/serial-communication/
Sat Nov 27 2010, 12:16 AM
hi onyot, neglect those many unnecessary ideas If u just want to make a password like system with display using lcd..
Onyot, your making this thread very long without a fixed idea. My advice to u my frnd s to make first a simple code of passwrd and lit a LED when passwrd s correct then modify 8 to more complex.
