Automatic Water Pump System
Discussion in "New Ideas regarding projects" started by coolmirza143 Nov 26, 2010.
Sun Nov 28 2010, 02:19 pm
i think commercial r available but normally used in industry automation not in general use
so its costly too
so its costly too
Mon Nov 29 2010, 12:21 am
hi all, about the sensor used in the schematic is that not a real comercial sensor available in the market?
as i have read its only stainless steel probs or chrome?romel_emperado
This type of circuit is often used in items like hot water boilers that fill themselves and
switch heaters to control the temperature.
The probes are always stainless steel, but that may be a food safety issue.
I think almost any non corroding metal will do.
Note.. for drinking water, chrome plating can use toxic metals, so best avoided.
The size is not important as the circuit is very sensitive.
Spacing depends on the use, so you don't see "standard" contact pairs.
romel_emperado like this.
Mon Nov 29 2010, 12:52 am
Spacing depends on the use, so you don't see "standard" contact pairs.ExperimenterUK
thanks... you answer my doubts...
Mon Nov 29 2010, 10:05 am
Project drawing... power portion is not included in this diagram........
i am using six sensor to detect water level and two more sensors are used one for flow detection and one to detect water intake....
using port zero to sens output of level detector sensors and for this i am using pull down resistor to detect 5v at an pin of Port 0.
8 LEDs are connected vertically with Port 1 and these will show the status of Tank....
LCD to show Tank status in numeric values like 10% full, 50 % full...etc.
Mon Nov 29 2010, 11:24 am
hi coolmirza143
lcd can be replace with 2 or 3 7-seg if u want with multiplexing module to minimize the cost
Mon Nov 29 2010, 11:39 am
Here is complete code now i am making Proteus simulation...... code is working fine no errors....
#include<reg51.h> sbit level1=P0^0; sbit level2=P0^1; sbit level3=P0^2; sbit level4=P0^3; sbit level5=P0^4; sbit level6=P0^5; sbit flow=P0^6; sbit intake=P0^7; sbit rs=P3^0; sbit rw=P3^1; sbit E=P3^2; sbit sw=P3^3; sbit lamp=P3^4; sbit buzzer=P3^5; sbit led1=P1^0; sbit led2=P1^1; sbit led3=P1^2; sbit led4=P1^3; sbit led5=P1^4; sbit led6=P1^5; void delay_ms(unsigned int x); void lcd_cmd(unsigned char x); void lcd_data(unsigned char x); void lcd_str(unsigned char *str); void lcd_init(); void main(){ while(1){ P0=0x00; //setting port zero low to monitor sensor o/p. lcd_init(); delay_ms(20); if(level1==1){ lcd_str("Tank Full"); lcd_cmd(0xc0); lcd_str("100 %"); led1=1; // LED 1 ON. buzzer=1; //buzzer ON lamp=0; //flow detection lamp Off delay_ms(3000); // 3 sec Delay. buzzer=0; //buzzer OFF. sw=0; // Water pump OFF. } if(level2==1){ lcd_str("Tank Status"); lcd_cmd(0xc0); lcd_str("85 %"); led2=1; } if(level3==1){ lcd_str("Tank Status"); lcd_cmd(0xc0); lcd_str("66 %"); led3=1; } if(level4==1){ lcd_str("Tank Status"); lcd_cmd(0xc0); lcd_str("50 %"); led4=1; } if(level5==1){ lcd_str("Tank Status"); lcd_cmd(0xc0); lcd_str("25 %"); led5=1; } if(level6==1){ lcd_str("Tank Status"); lcd_cmd(0xc0); lcd_str("15 %"); led6=1; if(intake==1){ sw=1; } } if(flow==1){ lamp=1; sw=1; } else{ sw=0; lamp=0; } }//while }//main /////////////////Functions/////////// void lcd_init(){ lcd_cmd(0x38); lcd_cmd(0x0C); lcd_cmd(0x01); } void delay_ms(unsigned int x){ unsigned int i,j; for(i=0; i<=x; i++){ for(j=0; j<=1000; j++){ ; } } } void lcd_data(unsigned char x){ rw=0; rs=1; P2=x; E=1; delay_ms(1); E=0; delay_ms(1); } void lcd_cmd(unsigned char x){ rw=0; rs=0; P2=x; E=1; delay_ms(1); E=0; delay_ms(1); } void lcd_str (unsigned char *str) { while(*str){ lcd_data(*str++); delay_ms(10); } }
[ Edited Mon Nov 29 2010, 11:53 am ]
Mon Nov 29 2010, 02:13 pm
nice work mirza..
mirza u can also use the 0x00 method in defining your I/0 ports to avoid using many sbit initialization.. your code will look short and simple..
Mon Nov 29 2010, 02:18 pm
romel any example for doing this ??? I didnt understand wat u wanna say!!
Mon Nov 29 2010, 02:37 pm
here.
main()
if(level==0x01){
lcd_cmd(0xc0);
lcd_str("100 %");}
if(level==0x02)
lcd_str("level status2");
lcd_cmd(0xc0);
lcd_str("85 %");}
main()
if(level==0x01){
lcd_cmd(0xc0);
lcd_str("100 %");}
if(level==0x02)
lcd_cmd(0xc0);
lcd_str("85 %");}
Mon Nov 29 2010, 02:41 pm
here.#include<reg51.h> # define level P0 // instead of sbit it can simply declare like this main() { while(1) { if(level==0x01){ lcd_str("Tank Full"); lcd_cmd(0xc0); lcd_str("100 %");} if(level==0x02) lcd_str("tank status"); lcd_cmd(0xc0); lcd_str("85 %");} }
romel_emperado
[ Edited Mon Nov 29 2010, 02:46 pm ]
