How to Interface an TOUCH SCREEN to a microcontroller
Thu Apr 07 2011, 01:11 pm
rescue me from this ........
>i will stick up with a resistive touch screen
>how can i interface a touch screen with a mc(specify which one to use)
>i have a idea of making a robo which wil move in the pattern drawn on the touch screen......is that possible
-----for example if i draw a circle my robo should make a circle
>i am not at advanced stage just a beginner with some knowledge on avr so what way i can make my robo come true
>i have googled for a long time i havn't found any sources........provide me if u have any
Thu Apr 07 2011, 02:18 pm
Hi shyam,
first i like to ask which touchscreen ur using... resistive touch means.. is it a HMI or touchreen module..
if it a HMI u can directly.. communicate with standard rs232 or rs485 hardware.... u can control the robot by entering data... one thing keep in mind... if u want to draw the graphical or gomentrical.. inputs means u have to try for a diff vendor.. to purchase a HMI..
shyam.sunder91 like this.
Thu Apr 07 2011, 03:20 pm
i dont know what HMI means but i am using a 4 wire resistive touch screen
can't i doit through a microcontroller,with out using a pc,actually my pc doesn't have serial ports...
can u mention the vendor,i want to do exactly what u meant...
Thu Apr 07 2011, 03:32 pm
http://www.advantech.in/products/WebOP-2057V/mod_D5F5789B-937D-4E69-BF25-3788B6AB6ABA.aspx
see the link it shows the HMI..
without using a pc u can control the robot with hmi
Thu Apr 07 2011, 03:46 pm
without using a pc u can control the robot with hmipravin_35
>COST matters here i want to make it cheap and simple im not willing to interface any application oriented kit .......but thanks for ur sugg.
my application itself is an HMI
Thu Apr 07 2011, 03:49 pm
k fine wat touch screen u r using and wat is the manufacturer name ... ?? plz post the datasheet or image of touch screen...
Thu Apr 07 2011, 03:56 pm
yes.......
touch screen
http://www.nskelectronics.in/_ds_touch_screen.html
data sheet:
http://www.nskelectronics.in/files/how20does20it20work.pdf
touch screen
data sheet:
Thu Apr 07 2011, 04:06 pm
so r u using dis controller
http://atmel.com/dyn/resources/prod_documents/doc8091.pdf
Thu Apr 07 2011, 04:21 pm
http://atmel.com/dyn/resources/prod_documents/doc8091.pdfpravin_35
iam not using this i want to read it just from the avr it self......
Thu Apr 07 2011, 04:27 pm
ya for u have to learn the 4 wire communication standard protocol .. from the touch screen manufacturer .. rite
