home automation system
Sat Apr 09 2011, 02:19 pm
Ajay sir ,
i m using NXP 89V51RD2 instead of atmel...so do i need to run da programs n create another hex code or the one with the project will work...??
sir n about the codes i jus wanted to know how to build the targets...like do it together or separately...??? do i add all the c files to da same source group..??
Sat Apr 09 2011, 09:40 pm
sir n about the codes i jus wanted to know how to build the targets...like do it together or separately...??? do i add all the c files to da same source group..??fatty
u just need to add all the c codes into the source group and compile it.....then u will get a hex code.......and then u can use this hex code for burning the microcontroller.......
u dont forget for configuring the target before compiling it, right click on the target option and click the "options for target " and also go in the "output" window and click on "create hex file" option.......this is all about compiling the
c code.......
fatty like this.
Sat Apr 09 2011, 09:56 pm
keil says target not created ....whn i build....whr does the hex file get stored....???
error is code size limit exceeded in restricted version...pls help...
Sat Apr 09 2011, 10:04 pm
hey fatty , in the keil evaluation version the code size are limitted to 2k...so u cant compile the codes more than 2k.......so u should use the keil full version software......
Sat Apr 09 2011, 10:16 pm
whr do i download da full version....n affter i build n run whr is da hex file stored...???
Sat Apr 09 2011, 10:24 pm
the hex file will store in the place that u are saved the project.....if ur microcontrolller is compatible for the 8051 , then u can use the hex code tat is given in the download section.......
Sat Apr 09 2011, 10:36 pm
@ fatty
yes it has same configuration
i just say that in some cases some pins are used for another purpose and need to configure but it look like that there is no need of configuration for this chip
u can download keil from here
if gets problem upload ur project folder here
1) http://ifile.it/rtkzpg4
or
2) http://ifile.it/rtkzpg4/keil.rar
or
fatty like this.
