Discussion in "New Ideas regarding projects" started by    vmax    Jan 30, 2008.
Fri Feb 01 2008, 10:30 am
AT77C102B has parallel interface so as u said u can use any controller at the cost of extra pins...
MBF-200 has all thesse interfaces...
(1) USB 1.1 for integration into computer applications.
(2) 8-bit parallel MCU interface
(3) SPI interface, a serial interface with 6 wires.
the problem is it captures images...... and authenticate s them all by itself... no embedded programming required...
so boring!!!!!
plus it wud be little expensive.
Fri Feb 01 2008, 11:09 am
so boring!!!!!
shyam
some people look for this..
Fri Feb 01 2008, 11:29 am
Thanks for your suggestions.
As AT77C102B has parallel interface, I think I can Directly Interface It with PC Through USB or Parallel port. It is also given in datasheets.
But If I want to make Embedded application and If I want to monitor Fingerprint In PC and and save to compare it next time,Then How can I make Use of MicrocontrollerAT89S52 or AT89S8252?
Can you explain me the flow of data?..
And What do you mean by using a controller at the cost of extra pins?.
So what are the modifications I need to do with Microcontroller?..
Thank you...
vmax
Fri Feb 01 2008, 01:30 pm
u will neeed less pin to interface with SPI as obvious so
"at the cost of extra pins"
when u r using with uC u will get a block of data all hex .. first u will have to save that data coorresponding to a picture(gray scale fingerprint) in RAM then to some eeprom or flash and then compare each byte with already stored image..
Sat Feb 02 2008, 09:04 am
AT77C102B gives 8-bit Fingerprint Image.
So, What will be the Size Of the Fingerprint Image?
What is size require for eeprom and RAM For storing the single Image ?
Can you provide me some link where I can Find the use of this sensor with SPI interface?
Thank you.............
vmax
Sat Feb 02 2008, 03:46 pm
vmax
vmax
if you wnant spoi interface.. go for AT77C104B
download application notes from atmel i already posted a link
http://www.atmel.com/dyn/resources/prod_documents/doc5380.pdf
here is one very useful link
http://www.analog.com/UploadedFiles/Application_Notes/112974217EE.325.Rev.1.08.2007.pdf
[ Edited Sat Feb 02 2008, 04:00 pm ]
Tue Apr 01 2008, 09:12 pm
Hello Everyone,
I have been searching for weeks, but have been unable to locate an Atmel AT77C104 sensor or any other sensor for that matter. I am doing a project similar to the one described above, but can't even get started because of this problem locating a sensor. Can ANYONE please help with contact info for a vendor??
Thanks in advance!
Richardgar
Sat Apr 20 2024, 11:05 am
