Discussion in "GSM and CDMA Discussion" started by    ponnus    Jul 6, 2012.
Fri Jul 06 2012, 12:20 pm
Hai,
I am using SIM 300 supported GSM modem.
I am able to transfer data through gprs, using Tata docomo and Airtel sim cards.
Now,when I used a Bsnl simcard, I am getting +PDP DEACT on entering AT+CIICR.
I tried these commands:
at+cgatt=1
OK
at+cgdcont=1,"IP","bsnlnet"
OK
at+cstt="bsnlnet",,
OK
at+ciicr
ERROR
+PDP: DEACT
at+cipshut
SHUT OK
OK
at+cipstatus
OK
STATE: IP INITIAL
at+cstt="bsnlnet",,
OK
at+cipstatus
OK
STATE: IP START
at+ciicr
ERROR
+PDP: DEACT
I have enough balance in my Sim card, activated for gprs, full network range.
I used the same commands for the other sim cards and is working properly.
Can you please help me?
Thanks.
Fri Jul 06 2012, 06:52 pm
Hai,
I tried the apn
bsnllive
Now I can attach to gprs, but I am getting a local ip.
When I send AT+CIPSTART command, I am getting only OK response, there is no CONNECT OK response. But it is giving ERROR:5 as response.
I tried a Bsnl sim card , which is in roaming. I am able to access internet using this.
using the first simcard, I am able to browse and download in my mobile.
Please help me................
Sat Jul 07 2012, 12:28 am
@ ponnus
try this sequence
AT
AT+CIPMODE=0
AT+CGATT=1
AT+CGDCONT=1,"IP","wap.warid"
AT+CSTT="wap.warid","",""
AT+CIICR
AT+CIFSR
AT+CIPHEAD=1
AT+CDNSORIP=1
AT+CIPSTART="TCP","www.wecuw.edu.pk","80"
AT+CIPSEND
Sat Jul 07 2012, 11:06 am
Hai majoka,
I've already tried by setting AT+CIPMODE=0.
But is still giving
ERROR
+PDP DEACT
on issuing AT+CIICR
Sat Jul 07 2012, 01:11 pm
I dont remember if these many commands are required for accessing gprs on sim300. You only need 3 commands to do successful communication over GPRS.
take a look at this thread:
Command set for SIM300 to send data to tcp server via gprs
try this.. after you power on your modem. make sure signal GSM is registered and strength is more then 10. give the following commands to bring up gprs connection:
AT+CSTT="bsnlnet","",""
AT+CIICR
AT+CIFSR
after this you should be able to connect to TCP/UDP ports. I believe bsnlnet only support connection to port 80 as its a browse only service. confirm it from customer care.
Sat Jul 07 2012, 06:26 pm
Hai,
I simplified the commands and is still giving error.
As I said, bsnl roaming sim is working. Airtel and tata docomo are working.
But this is not working. My doubt is that is it not supporting SIM300 modem
Mon Jul 09 2012, 10:08 am
is this SIM 64K?
Mon Jul 09 2012, 12:30 pm
Hai Ajay,
It is not written on top of the Sim card.
Is there any other way to identify it?
It is a new Sim card.
When I checked it using my mobile, it is showing space for 200 contacts
Thank you
[ Edited Mon Jul 09 2012, 01:13 pm ]
Mon Jul 09 2012, 11:30 pm
normally new sim card are of 64K
Tue Jul 10 2012, 10:27 am
Does SIM300 support all Simcards.? Is there any special commands for 64K? But my other simcards are 64K and are working.
[ Edited Tue Jul 10 2012, 10:41 am ]
