SIM 300 PDP DEACT
Wed Jul 11 2012, 10:09 am
no SIM300 is older modem and might not support 64K. If you can get new firmware for this modem, then its might be possible to support this sim. SIM300 is obsolete now and are not in production. all new designs are recommended to use SIM900 which is a similar modem using ARM9 core.
Wed Jul 11 2012, 10:16 am
Hai,
Thank you Ajay.
I will get a SIM900 modem soon. As you said, the problem might be outdated firmware. I'll update if I get the solution.
Thank you Ajay.
Wed Aug 01 2012, 05:10 pm
Hai,
Sorry for late update. I was with some other work.
Now, I got a new modem having SIM900 module. I tried the Sim card in that modem also. But the result is same. All other sim cards are working. But this one is not. i tried another bsnl simcard, and that is also working. Any idea why it is giving
ERROR
+PDP DEACT
on AT+CIICR command?
ERROR
+PDP DEACT
Thu Aug 02 2012, 09:59 am
Hai,
I think so. Because when I used it in my mobile, I can browse internet
Fri Aug 03 2012, 05:34 pm
hai,
Yes, i am using the same thing. But when i used the apn (bsnlstream and bsnllive), I getting OK response for AT+CIICR command.
But am getting an ip address starting with 10 series (I think this is a private ip. and bsnlnet will give public ip). With this when i use AT+CIPSTART, i am getting CONNECT FAIL response.
Sat Aug 04 2012, 01:39 pm
what ru typing after AT+CIPSTART
it take how much time to get ok or fail response after issuing the AT+CIPSTART command
if time is long then it may a weak signals or bad power supply
Sat Aug 04 2012, 06:45 pm
Hai,
With apn setting bsnllive and bsnlstream, when i typed
AT+CIICR
it gives OK.
But the ip i got starts with 10.XX.XXX.XXX
But on
AT+CIPSTART="TCP","www.google.com","80"
it gives
OK
and
CONNECT FAIL after 4 or 5 seconds.
The signal level is good and the power is also good (As i said, I can use other sim cards with the modems and can connect to internet).
Today,I got another bsnl simcard. it is also showing the same behaviour with the modems, but can use in my handset for browsing.
Does new bsnl sim cards not support this kind of gprs modules?
AT+CIICR
it gives OK.
But on
it gives
OK
and
[ Edited Sat Aug 04 2012, 06:47 pm ]
Mon Aug 06 2012, 01:19 pm
Hai,
I wonder how the mobile phones connect to internet using AT commands?
In my case, I am not able to connect through AT commands, but mobile can establish connection.
Anyone have an idea about this?
Thank you
Thank you
[ Edited Mon Aug 06 2012, 03:09 pm ]
