Discussion in "Project Doubts" started by    sjangra100    Mar 30, 2013.
Tue Apr 02 2013, 04:30 pm
i am beginer....i must clear u it......
sjangra100
Dont you think you should choose a project that suites your level? in that way you can learn more things in a simple way. you can make a high level project later onwards. This project needs good knowledge and understanding of electronics and components involved in it.
Mon Dec 30 2013, 10:13 pm
can you please tell me which battery do you have used and dc motor ? and what is CONN-SIL6 in circuit diagram?
Tue Dec 31 2013, 12:44 am
any 9v bat u can yes
i have use a ready made chassis which have BO type motor...search on any online shop for BO motors
CONN-SIL6 is a simple 6 pin connecter used to connect to BT module i have specified the pin connection to BT on right side of the CONN-SIL6
you can interface any how suitable to you ,using a connecter or direct soldering to module..
Be sure you give only 3.3 v to BT module
Tue Dec 31 2013, 09:34 am
How much it will cost me ? As my budget is max 1500 Rs.
Fri Jan 03 2014, 11:42 am
AmitSoni00718
@ Vega kit, Lamington Road ,Mumbai
you will get a Bluetooth module and the 2 motors at lessthen 1500 Bugs
Tue Feb 04 2014, 05:58 pm
How to supply 3.3 v to BT module? As u told to use 9v battery .
What is 1N4728A & its use ?
What should be speed (rpm) of motor?
How to interface microcontroller with PC? Did u use rs232?
[ Edited Tue Feb 04 2014, 10:16 pm ]
Tue Feb 11 2014, 10:57 pm
A 3.3V VOLTAGE regulator is avaliable in market use that and also read the respective datasheet
moter rpm any 50.100,200....rpm ...recommended 50 or 100 RPM moter
every micro have to use rs232 to interface to pc...for this plz google search
Sat Apr 05 2014, 10:44 pm
im also a beginner sir...
Sir please look at this HC-05 circuit diagram that was along with the zip file in this project.
Is this circuit a part of the main circuit?
Sun Apr 06 2014, 11:47 am
1) What is meant by AT Command of HC-05?
2) Is a special UART wire required to connect HC-05 with uc?
3) What other components are needed which are not in the circuit diagram?
4) What software and hardware should i use to burn the program into uc? - See more at: http://www.8051projects.net/forum-t63005-last.html#sthash.upEB5iVy.dpuf
Mon Apr 07 2014, 11:14 am
utaletxcyw
Wed Apr 17 2024, 10:21 am
