Discussion in "8051 Discussion Forum" started by    Malik_Umair    May 24, 2013.
Mon Jun 24 2013, 10:07 am
I appreciate your thinking and I will look forward for your contribution. Post your current code so I can help you solve issues. and also share SMS format you're sending.
Sat Jun 29 2013, 04:00 pm
Hello Ajay,
I am seriously fed up of this task. I have tried my best but unable to receive any SMS. I am sharing the whole code with you, please arrange it for me. Its been a month and a half that I am working on it. The interrupt routine for sending sms is working fine.
;       Program for Sending SMS through GSM network using
;       SIM900D and AT89C51
;       Upon wake-up goto MAIN, avoid using memory space, allocated
;       to interrupt vector table
           ORG 0H
            LJMP MAIN
 ;       ISR for External Interrupt 0 to send Message for
 ;       particular activated input
            ORG 03H
            LJMP CHECK
;         ISR FOR TIMER 0 INTERRUPT
           ORG 000BH  ; TIMER 0 INTERRUPT
                                                        ;This is your ISR where you will count
                                                       ;60 interrupts and set timer flag
        INC R6 ;increment counter
        CJNE R6, #60,OUT
        CALL TIMEDOUT
OUT:
        MOV TL0,#0CDH
        MOV TH0,#0FFH ;Reload timer again for 50ms
        RETI
TIMEDOUT:
        ; Timeout occured
        CLR TR0 ;stop timer now
        SETB TIMEOUT_FLAG
        RETI
;         The MAIN program for initilization
            ORG 30H
     ; to define TIMEOUT_FLAG you can use
        ; bit addressable area
        TIMEOUT_FLAG equ 0H ;0H means Address:20H[bit0]
MAIN:       MOV P1,#00H
            MOV P2,#00H
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            SETB P1.0
 START:     MOV IE, #83H
            ACALL SERIAL
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            LCALL CMGF
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL CSMS   ; SET t PHASE 1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL CNMI_READ
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL CPMS   ; SET THE READ & WRITE STORAGE TO SIM
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL CMGL   ; LIST SMS FROM LOCATION (CURRENTLY SET TO "ALL")
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
READ_AGAIN: LCALL INIT_TIMEOUT
            LCALL CMGR   ; READ THE STORED MESSAGE
            ;LCALL DELAY1
            ;LCALL DELAY1
            ;LCALL DELAY1
            ;LCALL DELAY1
WaitForStar:
        JB RI, CHECK_BYTE
        JB TIMEOUT_FLAG, READ_AGAIN ;TIMEOUT_FLAG is a bit variable that is set
                                    ; In ISR of timer that your initialized earlier
        SJMP WaitForStar            ;if no timeout is not received
                                    ;go back and check data received
CHECK_BYTE:
        MOV A, SBUF
        CLR RI
        CJNE A, '*', WaitForStar
WaitForCode:                           ;the next char is a command
           JNB RI,WaitForCode
            MOV A,SBUF
            CLR RI
            CJNE A,'1', ERROR    ; If TRUE then make P2.1 HIGH
            SETB P2.1
            Sjmp CommonExit
ERROR:
             SETB P2.2          ; If FALSE then make P2.2 HIGH
CommonExit:
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
            LCALL DELAY1
             CLR P2.1
             CLR P2.2
             CLR A
             LCALL CMGD    ; DELETE THE SMS STORED IN SIM
             LCALL DELAY1
             LCALL DELAY1
             LCALL DELAY1
             LCALL DELAY1
             LJMP START
  ;DELETE:   LCALL CMGD    ; DELETE THE SMS STORED IN SIM
   ;         LCALL DELAY1
   ;         LCALL DELAY1
   ;         LCALL DELAY1
   ;         LCALL DELAY1
   ;         LJMP START
 ; ERROR:    SETB P2.2
 ;           LCALL DELAY1
 ;           LCALL DELAY1
 ;           LCALL DELAY1
 ;           LCALL DELAY1
 ;           CLR P2.2
 ;           LJMP START
;   Sending ISR
            ORG 200H
CHECK:     JNB P1.0, CHECK
            ACALL SERIAL
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL CMGF
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL CNMI
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL CMGS
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL SALAM
            ACALL THIEF
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            ACALL DELAY1
            RETI
;   Subroutine for Sending one byte out of serial port
  TRAIN:    MOV SBUF,A
  HERE:     JNB TI,HERE
            CLR TI
            RET
;   Subroutine for initializing the serial port with 9600BPS
    SERIAL: MOV TMOD,#20H
            MOV TH1,#0FDH
            MOV SCON,#50H
            SETB TR1
            RET
 ;  Subroutine for CSMS
   CSMS:   MOV DPTR,#TABLE6
           MOV R7,#10
   LOOP6:  MOV A,#0
           MOVC A,@A+DPTR
           INC DPTR
           LCALL TRAIN
           DJNZ R7,LOOP6
           RET
 ;  Subroutine for CPMS
   CPMS:   MOV DPTR,#TABLE8
           MOV R7,#13
   LOOOOP: MOV A,#0
           MOVC A,@A+DPTR
           INC DPTR
           LCALL TRAIN
           DJNZ R7,LOOOOP
           RET
 ;  Subroutine for CMGL
   CMGL:   MOV DPTR,#TABLE7
           MOV R7,#14
   LOOP7: MOV A,#0
           MOVC A,@A+DPTR
           INC DPTR
           LCALL TRAIN
           DJNZ R7,LOOP7
           RET
; Subroutine for CMGR
    CMGR:   MOV DPTR,#TABLE9
            MOV R7,#10
    BACK:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
            DJNZ R7,BACK
            RET
;   Subroutine for CMGD
   CMGD:   MOV DPTR,#TABLE10
           MOV R7,#10
   BACK1:  MOV A,#0
           MOVC A,@A+DPTR
           INC DPTR
           ACALL TRAIN
           DJNZ R7,BACK1
           RET
;   Subroutine for CNMI_READ
 CNMI_READ: MOV DPTR,#TABLE11
            MOV R7,#18
    BACK2:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
            DJNZ R7,BACK2
            RET
;   Subroutine for CMGF
    CMGF:   MOV DPTR,#TABLE1
            MOV R7,#10
    LOOP1:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
        ;   ACALL DELAY
            DJNZ R7,LOOP1
            RET
    CNMI:   MOV DPTR,#TABLE2
            MOV R7,#18
    LOOP2:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
        ;   ACALL DELAY
            DJNZ R7,LOOP2
            RET
;   Subroutine for CMGS
    CMGS:   MOV DPTR,#TABLE3
            MOV R7,#22
    LOOP3:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
        ;   ACALL DELAY
            DJNZ R7,LOOP3
            RET
;   Subroutine for SALAM
    SALAM:  MOV DPTR,#TABLE4
            MOV R7,#18
    LOOP4:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
        ;   ACALL DELAY
            DJNZ R7,LOOP4
            RET
;   Subroutine for THIEF
    THIEF:  MOV DPTR,#TABLE5
            MOV R7,#31
    LOOP5:  MOV A,#0
            MOVC A,@A+DPTR
            INC DPTR
            ACALL TRAIN
        ;   ACALL DELAY
            DJNZ R7,LOOP5
            RET
;   Subroutine for delay
  DELAY:    MOV R0,#50
  RELOAD:   MOV R1,#50
  WAIT:     DJNZ R1,WAIT
            DJNZ R0,RELOAD
            RET
;   Subroutine for LARGE delay
  DELAY1:   MOV R0,#255
  RELOAD1:  MOV R1,#255
  WAIT1:    DJNZ R1,WAIT1
            DJNZ R0,RELOAD1
            RET
;   Subroutine for INIT_TIMEOUT
INIT_TIMEOUT:
        CLR TR0 ;make sure timer is stopped
        CLR TIMEOUT_FLAG
        MOV R6, #0 ;assuming r6 is used for counting interrupts
        ;INIT timer for 50ms approx. time period
        MOV TMOD,#00000001B  ; TIMER 0, MODE 1
        MOV TL0,#0CDH
        MOV TH0,#0FFH
        SETB TR0 ;start timer
        RET
;   Lookup Tables
  ORG 400H
  TABLE1:   DB "AT+CMGF=1",0Dh
  TABLE2:   DB "AT+CNMI=2,2,0,0,0",0Dh
  TABLE3:   DB 'AT+CMGS="03319018928"',0Dh
  TABLE4:   DB "ASSALAM-O-ALAIKUM",0Dh
  TABLE5:   DB "GSM is working",1Ah
  TABLE6:   DB "AT+CSMS=0",0Dh
  TABLE7:   DB 'AT+CMGL="ALL"',0Dh
  TABLE8:   DB 'AT+CPMS="SM"',0Dh
  TABLE9:   DB "AT+CMGR=1",0Dh
  TABLE10:  DB "AT+CMGD=1",0Dh
  TABLE11:   DB "AT+CNMI=2,2,0,0,0",0Dh
            END
[ Edited Sat Jun 29 2013, 04:01 pm ]
Sun Jun 30 2013, 02:58 am
My earlier tips were lost in the server hack.
This works on Proteus.
Your main error was in setting TMOD in "INIT_TIMEOUT"
Good luck
 Malik_Umair like this.
Sun Jun 30 2013, 01:19 pm
Yeah I was also finding our previous few posts. So you have initialized timer 0 and 1 in same instruction in "INIT_TIMEOUT", But I have also initialized the timer in serial communication "ACALL SERIAL". So I want to as will these two separate initialization will not effect the execution? Also please I didn't understand the TMOD 21H. Please esplain it. Have you tested this code? Is this working fine? Because I am totally failed in it
Mon Jul 01 2013, 11:41 am
I do not see any issues in the program that ExperimenterUK shared.
TMOD=21H will not effect anything, as for serial you initialized Timer 1 in mode2 which means TMOD = 0x20
and when you are initializing timer0 for timer we are using mode1 so TMOD should only set timer1 mode bits and should not effect any other bit in that register, so TMOD = 0x21 timer1 mode bits remain same/unmodified. SERIAL subroutine should only be called once in your program, please remove SERIAL call from ISR.
You need to debug your program as follows:
1. Connect your board to PC or somehow tap your controller's TX pin to see if your controller is sending commands properly or not.
2. You must see AT+CMGR=1 continuously after every 3 seconds
What is the format of SMS you are using? It must start from '*'
PS: Electronics project needs lot of patience.
Mon Jul 01 2013, 11:00 pm
Thank you to Dear Ajay and ExperimenterUK to help me, I have little modified the ExperimenterUK program because it was giving interrupt and subroutine error but now it is working fine I am receiving SMS perfectly. But I have noticed that when I send message from microcontroller and I feed the number like "03319018928" the message is send correctly but when I feed the number like "+923319018928" I am unable to send message (or message is not sending from the microcontroller). Please help me in this regard.
Also I want to get help in that how can I update the sending number through sending SMS to microcontroller. For-example like currently I have programmed the micro-controller that it will send messages to a number, i-e, 03319018928 and I have burned this program into microcontroller and the system is in function now. Now I want to change the number to which microcontroller send the number, so in order to switch off the system and re-program the microcontroller how can I update the new number by sending message to the system when it is operational?
Tue Jul 02 2013, 12:39 am
#27
Glad to hear it is working at last.
Malik_Umair
Easy, don't send numbers like "+923319018928"
Seriously, why are you adding "+92 to the number ?
What does your phone manual say about the numbers you can use ?
Malik_Umair
This will be complicated.
Could you store several alternative numbers and change which one used via SMS ?
that would be much easier.
[ Edited Tue Jul 02 2013, 12:40 am ]
Wed Jul 03 2013, 12:20 am
#28
try to avoid using ORG multiple time in your program. just keep on writing your assembler automatically assign space to code one after the other. anyways.. I think experimenterUK's suggestion is good do not add prefix... But i think problem is the way you have written the code. You might be chaning number but you forgot to change number of characters:
            MOV R7,#22 ; if you change size of TABLE3 then change value 22 here accordingly
best way is to end strings with 0H or null I will give example later.
Now regarding saving number.. you can define a memory area to store number and simply copy received sms over there.. and use that memory area as your mobile number. Its bit difficult try if you can. In your code if you receive sms starting from * then next byte contains your command if command is a number like 1, 2 etc then process them as you are doing already if your sms has + character then it means new number to set e.g. *+01234567890# read till # and move to memory and use it.
Bobbyerilar
Thu Mar 28 2024, 08:08 am
pb58
Thu Mar 28 2024, 05:54 am
Clarazkafup
Thu Mar 28 2024, 02:24 am
Walterkic
Thu Mar 28 2024, 01:19 am
Davidusawn
Wed Mar 27 2024, 08:30 pm
Richardsop
Tue Mar 26 2024, 10:33 pm
Stevencog
Tue Mar 26 2024, 04:26 pm
Bernardwarge
Tue Mar 26 2024, 11:15 am
