Discussion in "New Ideas regarding projects" started by    engr1931    Oct 28, 2013.
Mon Oct 28 2013, 10:20 pm
need help sir. how can i send data to micro controller using visual basic program into a network! kindly please give some idea
Tue Oct 29 2013, 01:19 pm
You mean you want to communicate with controller over network? Or you want to send controllers data over network through PC software. Please explain your question in detail
Tue Oct 29 2013, 02:03 pm
i mean sir I want to send data from PC to microcontroller using network as a communication line..
then i can control what data to send using PC application made in visual basic! ...
Wed Oct 30 2013, 09:16 am
Which controller are you working on? Does it have Ethernet port? And most importantly... A TCP/IP stack?
Sat Nov 02 2013, 10:34 pm
im using 2051 or 4051 microcontroller sir. maybe with ethernet port use in device.. without using tcp/ip stack.
i just planned to output my desired data to ethernet port of the PC using vb program.
[if im going to use tcp/ip stack. what am i going to do to make interaction between my device and the Pc.]
Sun Nov 03 2013, 12:11 am
The only practical way for a beginner is a serial to Ethernet module like this on ebay.
Note,you need serial to Ethernet NOT spi to Ethernet.
eBay item number:
13068335598
or even this WiFi version.
eBay item number:
400551970923
[ Edited Sun Nov 03 2013, 12:14 am ]
Sun Nov 03 2013, 03:39 pm
im not familiar using that device sir. just exploring for my final project
Wed Nov 06 2013, 03:12 pm
8051 is too small for this purpose as for Ethernet you need good amount of RAM and an Ethernet controller chip. 1K+ of ram is needed on controller with TCP/IP stack. without stack you wont be able to communicate to PC application. however your packet may be seen on capture applications like wireshark etc.
You can take a look at ENC28J60 ethernet controller over SPI.
Tue Nov 12 2013, 06:46 pm
is it possible to communicate with the device without using stack. ..i saw a project in the post they also use network to control the angle of the motor or the rotation
Wed Nov 13 2013, 06:36 am
engr1931
The serial devices I mentioned don't need a stack.
They are just a serial connection (serial uart type) at the controller end.
You will need some knowledge of using ports at the PC end.
Using any other method will need a stack and will be hard
