Discussion in "New Ideas regarding projects" started by    engr1931    Oct 28, 2013.
Fri Nov 15 2013, 10:29 am
@engr1931, you can post a link to such project. Let us investigate if its possible we will explain it to you.
Fri Nov 15 2013, 11:58 am
this sir. kindly explain sir. thank you
http://www.8051projects.net/download-d199-8051-controller-area-network-project-over-rs485-protocol.html
Fri Nov 15 2013, 07:58 pm
thats RS485 not RJ45 RS485 is similar to RS232 but a multi-client communicaton.
Fri Nov 15 2013, 11:31 pm
what do you mean by multi client sir? in the diagram ive seen RJ45.
forgive me if i keep on asking. im just an student now sir. i only know basic.
Sat Nov 16 2013, 12:04 am
engr1931
RJ45 just means the connector used.
The author perhaps had them handy, he could have used a 9 pin 'D'
In this case they are not being used to connect to the Ethernet local network.
Do you *need* to connect using the Ethernet network ?
There are simpler ways.
What are you doing exactly ?
Tue Nov 19 2013, 03:12 pm
i only want to know if i can output a data [using visual basic] to a ethernet port without using stack.
is it possible??
simplier ways? may i know what are those!?
Wed Nov 20 2013, 03:10 pm
It is possible but lot of programming involved. You need to use Wincap wrapper for .net to do so.. Here is a link that might be helpful for you:
http://stackoverflow.com/questions/3964013/how-send-raw-ethernet-packet-with-c
On controller side you still need an ethernet controller.
Wed Nov 20 2013, 10:28 pm
engr1931
I meant simpler ways to send data to a controller from a PC than using Ethernet.
eg an RS232 serial connection.
is it possible?
engr1931
Looking back at your thread I think Ajay and I may have misunderstood what you where asking.
You are asking about the PC end, we assumed you meant the controller end.
You may have a different meaning for "stack"
Internet software comes in layers.. many layers
The stack is part of the "sockets" software is built into Windows
it talks to the hardware.
I don't know Visual basic but I assume it has Internet functions either built in or
available as libraries that can talk to the sockets software.
Finally we get your code that uses the Visual basic Internet functions.
You can't send data over the net without using these specialist functions.
[ Edited Wed Nov 20 2013, 10:44 pm ]
Thu Nov 21 2013, 07:46 pm
thank you sir for guide. i think ill use serial now. than ethernet port, maybe ill just have to learn and experience all you suggest. thank you very much sir. more power.
